dynamitron
| strange result with float |
Posted: Sat Aug 04, 2012 7:25 am |
I have the following code with all variables typed as float:
| Code: | | dj = 16.5 - (temp_max_jour + temp_min_jour)/2; |
this operation give 0 all the time what ever the values I give to the variables.
In order to get a correct result I have to cut the code in pieces as follow :
| Code: | dj = temp_max_jour/2;
dj = dj + temp_min_jour/2;
dj = (16.5 - dj); |
Why ? any explanation ?
thanks for the answer !!
compiler PCWHD 4.093 |
FvM
Posted: Sat Aug 04, 2012 3:28 pm |
| PCWHD is a compiler package. You should tell the compiler PCB, PCM, PCH or PCD. At least PCD V4.093 had a number of bugs with complex expressions. |
dynamitron
Posted: Sat Aug 04, 2012 3:54 pm |
I use the compiler integrated in mplab.
I do not kown exactly if I use PCB, PCM, PCH or PCD all I know is that my processor is 18f2525. |
Posted: Sat Aug 04, 2012 4:05 pm |
Also, you should post a compilable test program so we can test your
problem. That way you might get an answer in the first reply.
I installed vs. 4.093 and made a test program and ran it in MPLAB
simulator. I got this result and it's correct:
#include <18F2525.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT
#use delay(clock=4M)
float dj;
float temp_max_jour;
float temp_min_jour;
temp_max_jour = 1.5; // 1.5 + 2.5 = 4.0
temp_min_jour = 2.5;
printf("dj = %7.3f \n\r", dj);
