Memory allocation doubt
naveen13m
PostPosted: Sat Jun 02, 2012 7:46 am     Reply with quote
I have a PIC16F882 microcontroller and it has a program memory of 3.5kb, 128 bytes of RAM. The file LCD.c is around 14kb and if my code is around 3kb then where will this lcd.c be stored in the microcontroller if i use lcd.c in my code ?
SherpaDoug
PostPosted: Sat Jun 02, 2012 9:41 am     Reply with quote
The .c code is not stored in the PIC. The .c code feeds the compiler which generates a much smaller binary image. It is this binary image which is stored in the PIC.
naveen13m
PostPosted: Sat Jun 02, 2012 1:11 pm     Reply with quote
If the programmable memory is only 3.5kb can i use both ADC and LCD at the same time i.e even after creating the image, will this be sufficient?
jeremiah
PostPosted: Sat Jun 02, 2012 1:23 pm     Reply with quote
It all depends on how much of the code you use. CCS only creates code for parts that you use. The only real way to know is toss a program into the compiler, compile it, and see how much space it takes up.
PostPosted: Sat Jun 02, 2012 2:51 pm     Reply with quote
Yes.
It is important to understand, that you can write one line of code, that uses several KB of actual ROM, or hundreds of lines that use just a few bytes. A single FP maths function, combining perhaps log's and sin's, can use more memory than many small PIC's have in them, but lines like defines, use no actual storage at all, till they are used, and even then only a very few bytes.
Now, the 16F882, does not have 3.5kb of memory. First, 'b' means bits, not bytes, but also the memory here is in 14bit 'words', of which it has 2048. Now to give an idea of what that can hold, I have a program, which uses flex_lcd, handles an I2C master, three ADC channels, keyboard, and a small command parser, which uses just 1881 words. 8.4KB, + 5KB, + 29.4KB + 20.7KB of source code.
However (conversely), I have another project here, which is under 4KB of source, and occupies 91000 words in the final chip.
You should be able to write a program that drives the LCD, and reads the LCD, occupying only a few hundred bytes. However switch to using complex arithmetic, and trying to print the results, and expect to have no hope at all....
