Pickit2 for 18f67k22
bolubeyi
PostPosted: Fri Apr 27, 2012 5:23 am     Reply with quote
Hi, I need some help. I have a 18f67k22 but I don't write 18f67k22 from pickkit2. What can I do?
n-squared
PostPosted: Fri Apr 27, 2012 6:00 am     Reply with quote
The PIC18FxxK22 family requires the PICkit3. The PICkit2 does not support it.
BR
NN
Every solution has a problem.
bolubeyi
PostPosted: Fri Apr 27, 2012 6:42 am     Reply with quote
Thank you for your answer, I have one more question Smile I use ccs c and pic c compiler. If I will use pickit3, is the problem make? Because write on pickit 3 datasheet supported by MPLAB IDE.
n-squared
PostPosted: Fri Apr 27, 2012 8:53 am     Reply with quote
bolubeyi,
I am sorry but I don't understand the question.
You are using two compilers and PICkit3 and ???
BR
NN
gpsmikey
PostPosted: Fri Apr 27, 2012 1:33 pm     Reply with quote
BR
NN
eh ? I use the 18F14K22 that I have programmed quite a bit using the PicKit2 - not sure about the other chips, but the "xx" does not apply for the "14" chips.
mikey
mikey
n-squared
PostPosted: Fri Apr 27, 2012 2:56 pm     Reply with quote
Mikey,
you are right about the xx not applying to 14.
the 67 and 46 series, on the other hand, is not supported by PICkit2.
Personally, I prefer the the PICkit2 as it is much faster that the 3.
BR
NN
gaugeguy
18Fxxk22
PostPosted: Mon Apr 30, 2012 8:17 am     Reply with quote
I have programmed both the 18F26k22 and 18F46k22 with the pickit 2 and the most recent device list.
Application 2.61.00, device file 1.62.14, Firmware 2.32.00
BINARIO
Question
PostPosted: Tue Sep 16, 2014 8:18 am     Reply with quote
can u tell me programmer and software that are you using?
