Running multiple instances of ccs compiler
ünloco
PostPosted: Sun Oct 02, 2011 12:57 pm     Reply with quote
Hello
I'm having an i2c master/slave project
and needed to run the two codes (projects) in parallel.
CCS is single instance (?) as I noticed !
But I managed to run it in multiple (2) instances by copying Pcw.exe and renaming it to Pcw2.exe, ....
it worked. But is there a safer way to run multiple projects/
ps: I had no problems so far
and I hope it isn't illegal :D
for(;;);
asmboy
PostPosted: Sun Oct 02, 2011 3:41 pm     Reply with quote
i use a text editor - ( multi edit ) with many open files at once possible and simply copy/ paste between "file tabs"
THEN when ready -just command line compile -
no conflict or confusion at all ;-))
ünloco
PostPosted: Sun Oct 02, 2011 5:07 pm     Reply with quote
that's a better solution i bet.
i'll try using npp !
for(;;);
ünloco
PostPosted: Fri Oct 07, 2011 5:02 am     Reply with quote
now i'm using notepad++
- open %appdata%\Notepad++\shortcuts.xml with any other editor than notepad++
- add this
        <Command name="Compile with CCS" Ctrl="yes" Alt="yes" Shift="yes" Key="0">&quot;c:\Program Files\PICC\Ccsc.exe&quot; &quot;$(FULL_CURRENT_PATH)&quot;</Command>
before </UserDefinedCommands>
press ctrl+alt+C to compile.
for(;;);
