Wolf
| A real stupid problem |
Posted: Mon Oct 03, 2011 5:54 pm |
Hey!
Ok here is my problem....I'm trouble shooting my circuit board, and all the bits on Port A, E, and 1 bit on C go directly to a socket so I can drop in an LCD screen. However, one of the bit's isn't working properly PIN_A4, or pin 6 positioned on PIC16F877. So I have hooked all the wires to LED's so I can see them work but I cannot make PIN_A4 work for the life of me. I looked at the datasheet and it says it's a bi-directional pin so I don't know.
here is my code:
#define LCD_DB7 PIN_A0
#define LCD_DB6 PIN_A1
#define LCD_DB5 PIN_A2
#define LCD_DB4 PIN_A3
#define LCD_ENABLE PIN_A4
#define LCD_RS PIN_C2
#define BACKLIGHT_RED PIN_E0
#define BACKLIGHT_GREEN PIN_E1
#define BACKLIGHT_BLUE PIN_E2
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=20000000) //Crystal Oscillator @ 20MHz
//#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
void StartupSettings();
StartupSettings();
while(1) {
output_bit(LCD_DB7, 1);
output_bit(LCD_DB6, 1);
output_bit(LCD_DB5, 1);
output_bit(LCD_DB4, 1);
output_bit(LCD_ENABLE, 1);
output_bit(LCD_RS, 1);
output_bit(LCD_DB7, 0);
output_bit(LCD_DB6, 0);
output_bit(LCD_DB5, 0);
output_bit(LCD_DB4, 0);
output_bit(LCD_ENABLE, 0);
output_bit(LCD_RS, 0);
return;
void StartupSettings() {
set_tris_a(0x00);
set_tris_c(0x00);
set_tris_e(0x00);
return;
Any ideas? |
bungee-
Posted: Mon Oct 03, 2011 6:14 pm |
Look at the datasheet again on page 42. There is a line on page 41 | Quote: | | The RA4/T0CKI pin is a Schmitt Trigger input and an open-drain output. | pay attention on underlined text
I had the similar experience the first time I came across this particular port.
For most application you can simply put 10k resistor to the 5V line. |
Wolf
Posted: Mon Oct 03, 2011 6:42 pm |
| Oh damn it! I guess I need to start cut up or solder parts off my circuit board. Thank you |
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
Posted: Mon Oct 03, 2011 10:59 pm |
| Wolf wrote: | | Oh damn it! I guess I need to start cut up or solder parts off my circuit board. Thank you |
No you just need to add a pull-up resistor. _________________ Regards, Andrew
