sawula
Posted: Fri Sep 23, 2011 12:27 am |
Hi scuba
Sawula-
MikroC is off-topic for the CCS compiler forum.
Find a MikroC forum or talk in a PM.
-- Forum Moderator
I am doing the same project with MRF89XA and PIC18F4550 using MIKROC Pro. And I am trying to convert your ccs code to Mikroc code. And I would like to know why are you using shif operations in registerset and registerRead functions ?
| Code: | address = (address<<1);
spi_write (address); |
| Code: | address = ((address<<1)|0x40);
spi_write(address); |
Can you please help me! |
scuba
Posted: Fri Sep 23, 2011 9:34 am |
This code can be seen in radiodriver.c and mrf89xa.c which is the site of the microchip. I just adapted. To better understand i suggest the datasheet of mrf89xa. I also didn't understand well but i think is for data to be allocated at different addresses.
Greets |
sawula
Posted: Tue Oct 11, 2011 1:47 am |
Hi scuba
How is progress of your project ? Were you able to communicate successfully? |
scuba
Posted: Thu Oct 13, 2011 4:02 am |
| Hi there, yes my project is done. |
feint
Posted: Tue Jan 03, 2012 2:38 am |
| scuba wrote: | | Hi there, yes my project is done. |
hello scuba can you share the code |
jeremy57350
Posted: Sat Feb 11, 2012 6:15 pm |
Hello, I'm currently on the same project as you. I sent an info temperature via this module. Can you share your code?
thank you |
Itronica
Posted: Thu Feb 16, 2012 8:00 am |
| Good morning, you can also have the file. H? Or the whole project? I am using the C18 with the library MIWI P2P but requires too many resources. thanks |
Mariusz
| Project files |
Posted: Tue Nov 08, 2016 2:13 am |
Hi.
Can somebody add sample code for mrf89xam8a for SERVER and CLIENT (send and receive data) including header files please.
Thank you |
