PCH pointers
Douglas Richard
PCH pointers
PostPosted: Mon Oct 28, 2002 3:00 pm     Reply with quote
Got the following code for the PCH compiler (18F248):
#define start_node_address 0X200
#define end_node_address 0X2FF
int *node_info;
node_info = start_node_address;
The above code will not compile and I will get this error:
Constant out of the valid range
If I do the following it will compile:
#define start_node_address 0X100
#define end_node_address 0X1FF
OR if I do this it will compile:
int32 *node_info;
long int *node_info; will not compile.
The above solutions are no solutions at all. I want to use the memory from 200 to 2FF and I believe int32 *node_info will give me a pointer to a double (instead of an interger).
any thoughts.
___________________________
Original Post ID: 8247
Mark
Re: PCH pointers
PostPosted: Mon Oct 28, 2002 3:22 pm     Reply with quote
:=Got the following code for the PCH compiler (18F248):
:= #define start_node_address 0X200
:= #define end_node_address 0X2FF
:= int *node_info;
:= node_info = start_node_address;
:=The above code will not compile and I will get this error:
:= Constant out of the valid range
:=If I do the following it will compile:
:= #define start_node_address 0X100
:= #define end_node_address 0X1FF
:=OR if I do this it will compile:
:= int32 *node_info;
:=long int *node_info; will not compile.
:=The above solutions are no solutions at all. I want to use the memory from 200 to 2FF and I believe int32 *node_info will give me a pointer to a double (instead of an interger).
:=any thoughts.
Original Post ID: 8249
Carlos Barberis
Re: PCH pointers
PostPosted: Mon Oct 28, 2002 4:16 pm     Reply with quote
Pointers to constants are not permitted, see pg 51 of CCS manual
:= int *node_info;
:=any thoughts.
Original Post ID: 8251
Mark
Re: PCH pointers
PostPosted: Mon Oct 28, 2002 6:42 pm     Reply with quote
He is not doing a pointer to a constant.
A pointer to a constant would be something like this:
char const mystring[6]={"Hello"}
ptr = mystring;
He is only assigning an address.
Regards,
Mark
:=Pointers to constants are not permitted, see pg 51 of CCS manual
:=:=Got the following code for the PCH compiler (18F248):
:=:= #define start_node_address 0X200
:=:= #define end_node_address 0X2FF
:=:= int *node_info;
:=:= node_info = start_node_address;
:=:=The above code will not compile and I will get this error:
:=:= Constant out of the valid range
:=:=If I do the following it will compile:
:=:= #define start_node_address 0X100
:=:= #define end_node_address 0X1FF
:=:=OR if I do this it will compile:
:=:= int32 *node_info;
:=:=long int *node_info; will not compile.
:=:=The above solutions are no solutions at all. I want to use the memory from 200 to 2FF and I believe int32 *node_info will give me a pointer to a double (instead of an interger).
:=:=any thoughts.
Original Post ID: 8255
R.J.Hamlett
Re: PCH pointers
PostPosted: Tue Oct 29, 2002 3:15 am     Reply with quote
:= int *node_info;
:=any thoughts.
You don't say which compiler version. I suspect this is a version of a fault I had with the CCS compiler, which has now (largely) been fixed, where if I generated pointers to an integer, I found the compiler generating 8 bit pointers. However if I generated pointers to int16 values, it used a 16bit pointer, and if I went to using pointers to int32 values it used 32bit pointers!.
This was fixed a while ago, but when I ran into this problem, I found the fault only affected certain pointer operations, so I could 'code round' the problem, by declaring my pointers to be to a larger data type, and then casting the resulting pointer to the right type in use.
So something like:
int32 *node_info;
node_info=start_node_address;
Then when I wanted to use the pointer, employing:
val=(int *)start_node_address;
The only problem with this, is that address arithmetic, then doesn't follow the normal rules...
Original Post ID: 8267
Mark
Re: PCH pointers
PostPosted: Tue Oct 29, 2002 6:49 am     Reply with quote
I know I typed a response but here is what I found.
The compiler would not allow a value greater than 0x1FF.
However this works great
#byte start_node = 0x200
#define start_node_address &start_node
#define end_node_address &start_node + 0xFF
int *node_info;
:=:=any thoughts.
Original Post ID: 8268
