Posted: Tue May 03, 2011 11:16 am |
You're programming in MPASM and this is a CCS C compiler forum.
Every compiler (or assembler) has it's own forum. Here's the forum
for MPASM:
http://www.microchip.com/forums/f16.aspx |
Nora
Posted: Fri May 06, 2011 6:28 am |
I never got these to work. I purchased a development board (AVR) with preloaded software on it just to look at the signals to figure out how it is supposed to work.
No joy.
The software (that I did not write) worked, but the signal between the 2 chips intercepted lots of noise about 2 meters apart in a non-noisy environment.
I decided that these modules require more RF knowledge than I possess.
Have moved on to Xbee, at least for now.
N_N |
krossroad07
Joined: 12 Mar 2011 Posts: 2 Location: Kathmandu,Nepal
Posted: Sun Jul 17, 2011 11:03 pm |
I've been trying to make rfm12b modules to work with PIC16F877A, but no luck till now. If any of you happen to have a working code or any suggestions, please help me out...... . |
sigma-mx
krossroad07
Posted: Thu Jul 21, 2011 11:09 am |
Well thanx mate..... After all the hardship, success at last.......  |
trancequality
| RFM22B NIRQ pin |
Posted: Fri Sep 02, 2011 8:18 am |
| Hello, is it possible to get RF data without using NIRQ pin?? |
picpgm
pingza1990
| Re: RFM12 driver for CCS C compiler |
Posted: Fri Dec 02, 2011 8:20 am |
Thank a lot  |
MUKULMOHAL
Posted: Thu Mar 05, 2015 1:56 am |
how we can read the status register?
i want to verify, whether the configuration i have done is correct or not, how should i proceed ? |
