MACHX not programming PIC16F526 or special programming?
muiratinas
PostPosted: Thu Nov 04, 2010 3:42 am     Reply with quote
In MACHX supported devices list
PIC16526 seems
* Indicates this part is in beta test
@ Indicates the MACH-X can not auto-detect this part type
But when i connect it to the its ZIF socket and try to program it gives an error that;
Error : Verification Error
Is there any special connection type, or CCS Load configuration to program that chip? If yes how it can be?
(my CCS Device Programmer Software 4.027, Firmware 0.87 and Hardware is Rev 5)
(and yes my mach x can program different chips so it's not broken Smile )
muiratinas
PostPosted: Fri Nov 05, 2010 12:32 am     Reply with quote
After the technical support, with the new firmware, the problem solved =)
thanks ccs support Very Happy
nanoulate
PostPosted: Thu May 05, 2011 8:26 am     Reply with quote
PIC24FJ256DA210 also has the * Indicates this part is in beta test issue. But it doesn´t appear in the target device list. The info says that MACH X does support this PIC. How can I make MACH X target list to show this PIC?
