output_high() in a "for(;;)" cycle
cmussoni
PostPosted: Sat Aug 21, 2010 8:02 am     Reply with quote
Hello to all,
I've this stupid doubt. In this code:
void main(){
   set_tris_c(0b00000000);
   for(;;){
      output_high(PIN_C0);
PIN_C0 is blinking with a 1 second rate. Why?
Why in this for-cycle the PIN_C0 turns off?
(I don't write "output_low(PIN_C0)" )
Thanks a lot to all.
Claudio
PostPosted: Sat Aug 21, 2010 8:21 am     Reply with quote
May be a case of the well-known RMW problem. Increase the load resistor connected to the output to achieve a legal logic "1" level at the pin.
Or did you enable the watchdog timer?
cmussoni
output_high() in a "for(;;)" cicle
PostPosted: Sat Aug 21, 2010 10:25 am     Reply with quote
I've no WDog (#fuses XT, NOWDT...). I don't try to change the output load but when I bring out the code :
from the infinite loop for(;;) the output blinks no more.
Any other idea ?
Thanks a lot
Claudio
cmussoni
PostPosted: Sat Aug 21, 2010 10:28 am     Reply with quote
...ooops... I remind I' m working with a PIC16F876A.
Bye.
dyeatman
PostPosted: Sat Aug 21, 2010 10:52 am     Reply with quote
Why don't you post the entire (compilable) program so we can test it rather than play guessing games?
Google and Forum Search are some of your best tools
cmussoni
PostPosted: Sat Aug 21, 2010 11:08 am     Reply with quote
Ok there it is :
#include <16F876A.h>
#fuses   XT, NOWDT, NOPROTECT, NOPUT, NOBROWNOUT, NOLVP
#use delay (clock=4000000)
#define  TX232 PIN_A2
#define  RX232 PIN_A5
#define  INTSP PIN_A4
#use rs232(baud=9600, xmit=TX232, rcv=RX232)
BYTE int_count;
#define INTS_PER_2_SECOND 20
#INT_TIMER0
int FLAGOK=0;
int timeout=0;
int DATOIN=0;
int current_b=0;
int current_c=0;
void  READDATA(){
   FLAGOK=0;
   delay_us(100);
   timeout=0;
   while(!kbhit() && (++timeout<5000)){   // 0,05 second
   delay_us(10);
   if(kbhit()){
      DATOIN=getc();
      FLAGOK=1;
   else {
      FLAGOK=0;
void main(){
   set_tris_a(0b00110010);
   set_tris_b(0b11111111);
   port_b_pullups(TRUE);
   for(;;){
      READDATA();
      delay_ms(200);
PostPosted: Sat Aug 21, 2010 11:19 am     Reply with quote
And the CCS version, please.
cmussoni
PostPosted: Sat Aug 21, 2010 11:41 am     Reply with quote
IDE 4.093
PCB 4.093
PCM 4.093
PCH 4.093
PCD 4.093
Cool
cmussoni
PostPosted: Sat Aug 21, 2010 11:52 am     Reply with quote
Sorry, sorry. The complete for-cycle is the sequence:
for(;;){
      current_b=input_b();
      delay_us(100);
      current_c=input_c();
      delay_us(100);
      READDATO();
      delay_ms(200);
PostPosted: Sat Aug 21, 2010 1:17 pm     Reply with quote
O.K. input_c() sets all port c pins to tri-state, because default #USE STANDARD_IO is in effect.
PostPosted: Sat Aug 21, 2010 2:57 pm     Reply with quote
OK.
Several problems.
You have a #int declaration, without interrupt handler code after it. Either get rid of this declaration, or put a handler there...
You have a timeout counter, going to 5000, declared as an integer. An int, in CCS, can hold 255 max. This will never timeout.
This is why you don't get a blink.
Then, if the timeout was working, your delay here will be several instructions more than 10uSec. In fact the time will probably be nearly twice this.
You do realise that using a software UART, you _must_ poll the pin at intervals no longer than 0.5 a bit time. Any data that arrives in the 1200mSec comprising the rest of your loop, _will_ be lost. The actual 'odds' of seeing a serial character, are extremely poor indeed.
cmussoni
PostPosted: Sun Aug 22, 2010 1:26 am     Reply with quote
FvM...THAAANKS for the solutions: input_c() set PORTC to input !!!
Thank also Ttelmah for all the other my oversights. Rolling Eyes
Bye
Claudio
