I2C Communication Problem using PIC16F877A
Goto page Previous  1, 2, 3, 4
electric2277
HMC6352 with PIC18LF4321
PostPosted: Thu Feb 18, 2010 5:27 pm     Reply with quote
I am trying to get my HMC6352 working with my PIC18LF4321, however when I use the code at the beginning of this post (slightly tweaked), I get very large number for the msb and lsb (the number is 4294836352).
Something to note is that I could not compile with
"lsb = SWReadI2C(0);"
I had to leave the '0' out in order to not have an "error [1204] too many arguments in function call"
My code is below:
#include "p18f4321.h"           // Define PIC18LF4321 registers and bits
#include "usart.h"            // Define Usart settings for serial output
#include "delays.h"            // def
#include <stdio.h>
#include "sw_i2c.h"
 * Configuration selections
#pragma config OSC = XT         // Use RA6 and RA7 for 1-4MHz crystal oscillator
#pragma config WDT = OFF        // Disable watchdog timer
#pragma config PWRT = OFF       // Disable power-up delay             //
#pragma config LVP = OFF        // Disable low-voltage programming       //
#pragma config MCLRE = ON       // Enable master clear pin //
#pragma config CCP2MX = RB3     // Connect CCP2 internally to RB3 pin //
#pragma config BOR = SOFT       // Brown-out reset controlled by software //
#pragma config BORV = 3         // Brown-out voltage set for 2.1V, nominal //
#pragma config LPT1OSC = OFF    // Deselect low-power Timer1 oscillator //
 * Global variables
#define HMC6352_I2C_WRITE_ADDRESS 0x42
#define HMC6352_I2C_READ_ADDRESS  0x43
#define HMC6352_GET_DATA_COMMAND 0x41
 * Function prototypes
void Initial(void);
void InitTX(void);
void InitI2C(void);
void HMC6352_read_heading(void);
void HMC6352_read_heading()
   int lsb;
   int msb;
   int addy;
   SWStartI2C();                              //i2c_start();
   SWWriteI2C(HMC6352_I2C_WRITE_ADDRESS);      //i2c_write(HMC6352_I2C_WRITE_ADDRESS);
   SWWriteI2C(HMC6352_GET_DATA_COMMAND);         //i2c_write(HMC6352_GET_DATA_COMMAND);
   SWStopI2C();                           //i2c_stop();
   Delay1KTCYx(40);    //delays 4000 cycles of 4 MHZ = 1 ms   //delay_ms(7);  // Allow 1 ms extra for safety
   SWWriteI2C(HMC6352_I2C_READ_ADDRESS);      //i2c_write(HMC6352_I2C_READ_ADDRESS);
   msb = SWReadI2C();                     //msb=i2c_read();
   lsb = SWReadI2C(0);                     //msb=i2c_read(0);
   printf("MSB = %lu\n\r", msb);
   printf("LSB = %lu\n\r", lsb);
/////// Main program //////////////////////////////////////////////////////////
 * main
    Initial();                  // Initialize everything
   InitTX();               // Initialize the UART
   printf("Compass Heading = ");
   while (1)
     HMC6352_read_heading();
   Delay10KTCYx(100);
 * Initial
 * This function performs all initializations of variables and registers.
void Initial()
   OSCCON = 0b01100010;         // Use Fosc = 4 MHz (Fcpu = 1 MHz)
   ADCON1 = 0b00001011;         // RA0,RA1,RA3 pins analog; others digital
   TRISA = 0b00001111;          // Set I/O for PORTA
   TRISB = 0b00010000;          // Set I/O for PORTB
   TRISC = 0b00001100;         // Set I/O for PORTC
   TRISD = 0b10000000;          // Set I/O for PORTD
   TRISE = 0b00000010;          // Set I/O for PORTE
   PORTA = 0;                   // Set initial state for all outputs low
   PORTB = 0;
   PORTC = 0;
   PORTD = 0;
   PORTE = 0;
   Delay10KTCYx(50);
   RCONbits.SBOREN = 0;         // Now disable brown-out reset
void InitTX()
RCSTA = 0b10010000; // Enable UART
TXSTA = 0b00100000; // Enable TX
SPBRG = 12; // Set baud rate  corresponds to 19200 baudrate
BAUDCON = 0b00001000;
PostPosted: Thu Feb 18, 2010 5:34 pm     Reply with quote
You're using the Microchip C18 compiler. This forum is for the CCS compiler.
electric2277
CCS Compiler
PostPosted: Fri Feb 19, 2010 10:39 am     Reply with quote
Where do I go to get the CCS Compiler. I am guessing that it is not free.
Page 4 of 4
