i2c device address?
rret
i2c device address?
PostPosted: Wed Dec 09, 2009 12:28 pm     Reply with quote
I'm trying to talk to a NXP PCF8593 RTC chip.
http://www.nxp.com/documents/data_sheet/PCF8593.pdf
the other "end" is a PIC 16F877A.
From the PCF8593 Data Sheet the slave address is:
1 0 1 0 0 0 1 R/!W (8 bits total)
I do this:
int1 ack;
output_float(PCF8593_SCL);
output_float(PCF8593_SDA);
//pulse NOTRESET-
output_low(PCF8593_NOTRESET);
output_high(PCF8593_NOTRESET);
i2c_start();
ack = i2c_write(0x0A);         //???
Is the 0x0A correct? Or should I send some other value such as 0xA2?
PostPosted: Wed Dec 09, 2009 12:36 pm     Reply with quote
For CCS functions, the i2c write address is 0xA2 and the read address
is 0xA3.
In fact, it says this on the left side of page 3 of the PCF8593 data sheet:
· Slave address:
– READ A3
– WRITE A2
rret
thanks
PostPosted: Wed Dec 09, 2009 1:01 pm     Reply with quote
thanks, i really missed that info! Embarassed
