Help me control brightness Led using PWM module
Goto page 1, 2  Next
tienchuan
PostPosted: Wed Aug 26, 2009 12:22 am     Reply with quote
I have learn about pic16f877a last month. I have problems with PWM with PIC16F877A, and I don't myself understand it. Bad Bad Bad, I think I wrong with learning of me.
Can you have help me to control brightness of led using PWM Module of Pic 16F877A ?
Thanks you all you !
P/S: I'm vietnamese, so english skill of me very bad !!!!
Begin Begin Begin !!!
PostPosted: Wed Aug 26, 2009 11:34 am     Reply with quote
Can you have help me to control brightness of led using PWM module
of Pic 16F877A ?
Here is demonstration program.
This program creates a PWM output signal on the CCP1 pin.
It reads a trimpot voltage (from 0v to +5v) on pin A0, and
converts it to a PWM duty cycle value. Connect an LED to
(and 470 ohm series resistor) to the CCP1 pin. As you turn
the trimpot, the LED brightness will change.
#include <16F877A.h>
#device adc=8
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int8 value;
setup_ccp1(CCP_PWM);
// Set the PWM frequency for 244 Hz (with a 4 MHz crystal)
setup_timer_2(T2_DIV_BY_16, 255, 1);
setup_port_a(AN0);
setup_adc(ADC_CLOCK_DIV_8); // Divisor for 4 MHz crystal
set_adc_channel(0);
delay_us(20);
   value = read_adc();
   set_pwm1_duty(value);
tienchuan
PostPosted: Wed Aug 26, 2009 6:32 pm     Reply with quote
Thank you very much ! Very Happy
But, I want the PWM Module to run automatically by using loop statement to drive value of cycle duty !
Thank you !
See you soon Cool
PostPosted: Wed Aug 26, 2009 7:22 pm     Reply with quote
1. Delete all 4 lines of code that setup the ADC.
2. Delete the line that reads the ADC in the while() loop.
3. Above the while() loop, set the 'value' variable to 0.
4. Inside the while loop, increment the 'value' variable by 1
after the set_pwm1_duty() statement.
5. Inside the while loop, add a delay_ms(10) statement at the end
of the loop.
tienchuan
PostPosted: Thu Aug 27, 2009 9:54 pm     Reply with quote
First, thanks PCM programmer help me !
This code after edit with manual of you !
But it is run no correct. It is very slow, although I change value of cycle_duty!
Can you help me ?
#include <16f877a.h>
#include <def_877a.h>
#fuses nowdt,noprotect,put,xt,hs
#use fast_io(c)
#use delay(clock=12000000)
int8 i,value;
trisc=0x00;
output_low(PIN_C1);
setup_timer_2(T2_DIV_BY_4, 255, 1);
//code nay dung dieu khien PWM bang bien tro mac o chan AN0 theo kieu doc ADC
            //setup_port_a(AN0);
            //setup_adc(ADC_CLOCK_DIV_8); // Divisor for 4 MHz crystal
            //set_adc_channel(0);
            //delay_us(20);
  portc=0x00;
  value =0;
   for (value=1;value<=200;++value)
         delay_ms(30);
thanks you verymuch !
SEE YOU SOON !
PostPosted: Thu Aug 27, 2009 10:06 pm     Reply with quote
it is very slow
Your code is different from my description. That might be the reason why
it's slow.
You have done several other changes from my original program.
Some of the are not needed. Other changes might be a mistake.
tienchuan
PostPosted: Wed Sep 02, 2009 1:03 am     Reply with quote
you can manual me do !
I only have a pic16f877a !
thank you !
mutthunaveen
hey try this
PostPosted: Wed Sep 02, 2009 8:04 am     Reply with quote
this works fine in my hardware
#use delay(clock=14000000)
void main(){
int data;
delay_ms(50);
setup_timer_2(T2_DIV_BY_1,254,1);
setup_ccp1(ccp_pwm);
while(1){
   data=data+5;
   if(data==255){data=0;}
   delay_ms(50);
   set_pwm1_duty(data);
Try this dude it is simple Laughing
bkamen
PostPosted: Thu Sep 03, 2009 3:51 pm     Reply with quote
You really want to use hardware PWM though. It's free hardware dedicated to the task of toggling and timing.
This is good and efficient hardware usage.
Regards,
-Ben
tienchuan
PostPosted: Tue Sep 08, 2009 10:18 pm     Reply with quote
Regards,
-Ben
you can tell clearly, i don't think xxx ?
tienchuan
PostPosted: Tue Sep 08, 2009 10:19 pm     Reply with quote
oh no, i can control all port with PWM ?
Question Question Question
quocchien276
PostPosted: Thu Jul 08, 2010 11:47 am     Reply with quote
Welcome tieuchuan.
I am Vietnamese and this should be written in English.
I also like you, am having trouble at school before the new day.
Using the pic16f877a for PWM is too difficult.
Can you can send me some code examples to light up an LED gradually ?
Because then my problem will be settled.
Thank you very much
chào bạn tieuchuan.
là người Việt lun nên khỏi cần viết tiếng Anh. Very Happy
Mình cũng đang gặp khó khăn giống bạn lúc trước đây.mình mới học pic16f877a được 1 tháng.Đến phần PWM thì gặp khó khăn quá.
Bạn có thể gửi cho mình code ví dụ làm cho mấy led sáng dần rùi tối dần dần được ko?Vì vấn đề này chắc hẳn bạn đã giải quyết được rồi.
quocchien276
PostPosted: Fri Jul 09, 2010 5:00 am     Reply with quote
Tieuchuan,
Please help me.
PostPosted: Fri Jul 09, 2010 12:08 pm     Reply with quote
Tienchuan is gone from the forum.
The PWM code to control the brightness of an LED was posted near
the start of this thread. Here is the link:
http://www.ccsinfo.com/forum/viewtopic.php?t=40007&start=1
alex_ccs
PostPosted: Wed Oct 27, 2010 9:46 am     Reply with quote
Hi PCM programmer,
I have some question.
1. Can I simulate your source code on Proteus?
2. POT 1K is ok?
Goto page 1, 2  Next
Page 1 of 2
