SED1335 GLCD problem :(
Guest #2
PostPosted: Sat Jun 20, 2009 1:44 am     Reply with quote
Help, I'm stuck. I connected the SED1335 based EW32FA0FLW (datasheet: www.acds.fr/pdf_produits/EW32FA0FLW.pdf) to PIC 18F452, all wiring is correct and double checked, I modified sed1335.c to match control lines I connected (on port B, port D is data). Didn't forget to call glcd_init(ON). My problem is that only backlight comes alive, absolutely nothing on LCD can be seen ... what am I missing, any ideas or hints where to look?
PostPosted: Sat Jun 20, 2009 4:45 am     Reply with quote
Update: LCD now shows only garbled text - random black and white pixels. Any ideas what to check?
sliders_alpha
PostPosted: Sat Jun 20, 2009 3:16 pm     Reply with quote
i use those driver with a RA8835 : http://www.ccsinfo.com/forum/viewtopic.php?t=34970&start=30
and was getting the same problem, the CCS init is wrong, layer are not defined correctly (text and graphic layer) and their fillscreen and filltextscreen are also wrong.
use this instead :
init :
void glcd_RAinit(void)
   output_high(GLCD_RST);
   output_high(GLCD_CS);
   output_high(GLCD_RD);
   output_high(GLCD_WR);
   //system set
   glcd_sendCMD(0x40);
   DATA_MODE
   glcd_sendByte(0x30);
   glcd_sendByte(0x87);
   glcd_sendByte(0x07);
   glcd_sendByte(0x27);
   glcd_sendByte(0x2F);
   glcd_sendByte(0xEF);
   glcd_sendByte(0x28);
   glcd_sendByte(0x00);
   //scroll
   glcd_sendCMD(0x44);
   DATA_MODE
   glcd_sendByte(0xF0);
   glcd_sendByte(0x80);
   glcd_sendByte(0x25);
   glcd_sendByte(0x4B);
   //HDOT SCR
   glcd_sendCMD(0x5A);
   DATA_MODE
   //OVLAY
   glcd_sendCMD(0x5B);
   DATA_MODE
   glcd_sendByte(0x01);
   //erase all screen
   FillGraphic(OFF);
   FillText(' ');
   //DISP ON
   glcd_sendCMD(0x58);
   DATA_MODE
   glcd_sendByte(0x56);
   //CSRFORM
   glcd_sendCMD(0x5D);
   DATA_MODE
   glcd_sendByte(0x04);
   glcd_sendByte(0x86);
   //DISP ON
   glcd_sendCMD(0x59);
   //CSDIR
   glcd_sendCMD(0x4C);
   //CSRW
   setCursorAddress(0x0000);
fillscreen :
#define COMMAND_MODE   output_high(GLCD_A0);
#define DATA_MODE       output_low(GLCD_A0);
void setCursorAddress(int16 addr)
   int8 adress;
   glcd_sendCMD(0x46);
   DATA_MODE
   adress = addr & 0xFF;
   glcd_sendByte(adress);
   adress = addr >> 8;
void FillGraphic(int1 parameter)
   long count;
   //set cursor to 2580h
   setCursorAddress(0x2580);
   //put 00h in all graphic space
   count = 9600;
   glcd_sendCMD(0x42);
   DATA_MODE
   while(count != 0)
      glcd_sendByte(0xFF * parameter);
      count--;
void FillText(char cara)
   long count;
   //set cursor to 0000h
   //put 00h in all text space
   count = 1200;
   glcd_sendCMD(0x42);
   DATA_MODE
   while(count != 0)
      glcd_sendByte(cara);
      count--;
when you'll make it work, could you try to draw a circle (with graphic.c) and tell me if it works?
yup, i know, i don't speak english very well
CCS V4.057
PostPosted: Mon Jun 22, 2009 7:03 am     Reply with quote
Hello! I managed to get it to work after painstakingly going through the datasheet and doing my own init sequence and writing my own send/receive and glcd_pixel routines, now graphics.c works with my library and all is well! And yes, drawing a circle works too! Smile
sjharris
PostPosted: Tue Aug 11, 2009 3:40 am     Reply with quote
Care to post the INIT code??
SH
bkamen
PostPosted: Tue Aug 11, 2009 9:41 pm     Reply with quote
Post it in the code examples.. not here. :D
-Ben
