problems with timer1
Andreas Klittich
PostPosted: Tue Sep 11, 2001 8:19 am     Reply with quote
Hallo together,
I am beginning to work with PICs, therefore I have very easy questions to you.
PIC: 16C62A
I try to program timer1, but the timer1_isr is never starting.
First I init timer1:
tmr1l =0x00;
tmr1h =0x00;
t1con = 0b00110000;
Then I enable the interrupts:
ENABLE_INTERRUPTS (GLOBAL);
ENABLE_INTERRUPTS (INT_TIMER1);
Perhaps you can help, and tell me what is missing/wrong.
Thanks in advance.
Andreas
___________________________
Original Post ID: 241
Re: problems with timer1
PostPosted: Tue Sep 11, 2001 12:25 pm     Reply with quote
:=I am beginning to work with PICs, therefore I have very easy questions to you.
:=PIC: 16C62A
:=I try to program timer1, but the timer1_isr is never starting.
:=First I init timer1:
:= tmr1l =0x00;
:= tmr1h =0x00;
:= t1con = 0b00110000;
:=Then I enable the interrupts:
:= ENABLE_INTERRUPTS (GLOBAL);
:= ENABLE_INTERRUPTS (INT_TIMER1);
You are writing code as if you have Hi-Tech C, where
PIC peripherals have to be handled by low-level code.
But with CCS, you have high-level C functions to handle
these things. For example, CCS has these functions:
setup_timer_1(mode);
set_timer1(value);
These are describe in the manual, and if you look
in the folder for \PICC\Examples, you will see these
files, which show how to do it:
EX_FREQC.C
EX_PATG.C
EX_SPEED.C
Original Post ID: 242
Gabriel Caffese
PostPosted: Sat Jun 22, 2002 10:30 am     Reply with quote
PCM Programmer,
I havenīt got the Freqc and the Speed examples. Where can I download them from ? (cause can not do it from the CCS web site.)
Gabriel.-
:=:=I am beginning to work with PICs, therefore I have very easy questions to you.
:=:=PIC: 16C62A
:=:=I try to program timer1, but the timer1_isr is never starting.
:=:=First I init timer1:
:=:= tmr1l =0x00;
:=:= tmr1h =0x00;
:=:= t1con = 0b00110000;
:=:=Then I enable the interrupts:
:=:= ENABLE_INTERRUPTS (GLOBAL);
:=:= ENABLE_INTERRUPTS (INT_TIMER1);
:=You are writing code as if you have Hi-Tech C, where
:=PIC peripherals have to be handled by low-level code.
:=But with CCS, you have high-level C functions to handle
:=these things. For example, CCS has these functions:
:=setup_timer_1(mode);
:=set_timer1(value);
:=These are describe in the manual, and if you look
:=in the folder for \PICC\Examples, you will see these
:=files, which show how to do it:
:=EX_FREQC.C
:=EX_PATG.C
:=EX_SPEED.C
Original Post ID: 5129
