fw up to date
lollo
fw up to date
PostPosted: Thu Jun 11, 2009 6:34 am     Reply with quote
When I launch ccsload with ICD-U64 connected I receive the message "firmware is up to date".
I've tried to update the firmware with all the versions I have, but no result.
Have you any suggestion?
lollo
PostPosted: Thu Jun 11, 2009 8:54 am     Reply with quote
Sorry, I had to say "out of date"
mvanvliet
PostPosted: Fri Jun 12, 2009 6:35 am     Reply with quote
I've got the same message when opening ccs loader. I've tried version 2.6C and 2.62 both with the same message. The programmer is working fine. I think that the message came with the update of ccs loader. Before that I haven't got this message.
PostPosted: Mon Jun 15, 2009 2:23 am     Reply with quote
I update the firmware to 2.62 version and delete 2.6c version (ccs support workaround) and now ccsload works fine.
schayka53
Firmware out of date???
PostPosted: Wed Sep 01, 2010 6:47 am     Reply with quote
CCSLOAD #10000 is reporting "Firmware out of Date".
This is a new ICD-U64 installation.
How do I correct this issue?
mcafzap
PostPosted: Tue Nov 09, 2010 2:17 pm     Reply with quote
Over a month later and no solution although things appear to work OK despite it.
parasram
Same issue here
PostPosted: Wed Mar 30, 2011 1:41 pm     Reply with quote
I have a new U64 with firmware 2.85. Software is 4.028 and Hardware is Rev 2.
Is there a fix for this?
