64-bit output
todd
64-bit output
PostPosted: Thu May 09, 2002 3:43 pm     Reply with quote
Hello All,
I am trying to output 64-bits of data serially at a 2kHz rate through a single output pin. I am using the shift_left command to do this. My partial code is:
byte chan0[8] = {0xF6, 0xDB, 0x6D, 0xB7,
0xBD, 0xB7, 0xBD, 0xEF};
//// *** output here **** /////
for (n=0; n<8; n++)
for (m=0; m<8; m++)
// output MSB of byte[n]; 1-byte only; replace w/ 0
signal_temp = chan0[n];
output_bit(PIN_B0, shift_left(signal_temp, 1, 0));
delay_us(500); //sets 2kHz rate
I am not seeing anything out of PIN_B0. Through troubleshooting, I know that the routine is being called and that the for-loop is running correctly. I think that the problem is with the shift_left command (I used an example from the CCS help files, but don't have any other documentation on how this works).
Does anyone see anything wrong w/ my code? Or does anyone know a better way to output a 64-bit signal serially at a 2kHz (the order needs to be MSB -> LSB)?
Thanks in advance for anyone w/ input!
___________________________
Original Post ID: 4265
Todd C. Micallef
Re: 64-bit output
PostPosted: Thu May 09, 2002 7:07 pm     Reply with quote
<font face="Courier New" size=-1>First, since you didn't list the entire program it's hard to determine the port b problem. My guess would be that you don't have the port b pull-ups enabled(if the chip supports them).
The function PORT_B_PULLUPS(TRUE); should help if this is the reason you don't see the value change.
Second look at the file "ex_sqw.c" for an example on sending data at a specific rate.
Try making these other changes...
No guarantees this is 100\% correct, but should get you in the ballpark.
:=Hello All,
:=I am trying to output 64-bits of data serially at a 2kHz rate through a single output pin. I am using the shift_left command to do this. My partial code is:
for(n=0;n<64;n++)
output_bit(PIN_B0, shift_left(chan0, 8, 0));//8=8bytes
delay_us(250); //sets 2kHz rate
output_bit(PIN_B0,0); //If bit was high, goes to low: 50\%duty
delay_us(250);
:=I am not seeing anything out of PIN_B0. Through troubleshooting, I know that the routine is being called and that the for-loop is running correctly. I think that the problem is with the shift_left command (I used an example from the CCS help files, but don't have any other documentation on how this works).
:=Does anyone see anything wrong w/ my code? Or does anyone know a better way to output a 64-bit signal serially at a 2kHz (the order needs to be MSB -> LSB)?
:=Thanks in advance for anyone w/ input!</font>
Original Post ID: 4269
Mark
Re: 64-bit output
PostPosted: Thu May 09, 2002 10:58 pm     Reply with quote
The shift left command is used to shift bits into an array. I do not think it returns the value shifted out. If it did, I see a problem in your logic. Each time through the m for loop the signal_temp gets reassigned. It should have been outside the m loop. If I were doing this, I would do something like the following:
for (n=0; n<8; n++)
for (m=0; m<8; m++)
if (signal_temp & 0x80)
output_high(PIN_B0);
output_low(PIN_B0);
signal_temp <<= 1;
Depending on what you are doing, you could also use a timer int to avoid wasting CPU time.
Mark
:=Hello All,
:=byte chan0[8] = {0xF6, 0xDB, 0x6D, 0xB7,
:= 0xBD, 0xB7, 0xBD, 0xEF};
:=//// *** output here **** /////
:=for (n=0; n<8; n++)
:= for (m=0; m<8; m++)
:= // output MSB of byte[n]; 1-byte only; replace w/ 0
:= signal_temp = chan0[n];
:= output_bit(PIN_B0, shift_left(signal_temp, 1, 0));
:= delay_us(500); //sets 2kHz rate
Original Post ID: 4273
