Driver For SHT75 Temperature & Humidity Sensor
Goto page Previous  1, 2, 3  Next
delene
PostPosted: Mon Jul 21, 2008 1:17 pm     Reply with quote
My code also returns -4.6 and -39.9... :(
I have tried the suggestions above and still no joy
Any other suggestions???
tony-montana
help
PostPosted: Mon Jan 12, 2009 11:12 am     Reply with quote
hello. I have a problem with the sensor sht1xx and I'm using the same program that I was going to sht75 temperature and gives me a very rare. Can you help me thanks.
void sensor ()
sht_rd (restemp, truehumid) / / measure and calculate
lcd_gotoxy (1.1) / / write in 1.1
printf (lcd_putc, "Temp:% 3.1f% cC" restemp, 223); / / sensor
printf (lcd_putc, "\ nRH:%%% 3.1f" truehumid); / / sensor
Pol
PostPosted: Wed Jan 21, 2009 4:29 am     Reply with quote
Hello, i have a problem with this driver , i use 18f1320 @ 8mhz : i don't have answer from sensor, but if tune up the pic-clock (to 16mhz) the sensor start to answer me.... where is the clock-dependent sub of this cod ??? Thanks...
To boldly go where no one has gone before...
asmallri
Re: Driver For SHT75 Temperature & Humidity Sensor
PostPosted: Wed Jan 21, 2009 8:09 am     Reply with quote
Sound like you might be missing the pull up resistors.
Regards, Andrew
Diego Oliveira
PostPosted: Fri Jan 23, 2009 12:26 pm     Reply with quote
Someone has a library of SHT75 to PIC18F, I have already commented on the changes in the forum but none solved.
Grateful for the attention.
asmallri
PostPosted: Fri Jan 23, 2009 12:39 pm     Reply with quote
I sell a driver for the SHT75 - if interested check out: http://www.brushelectronics.com/index.php?page=software#SENSIRION
Regards, Andrew
crocu
PostPosted: Mon Nov 02, 2009 4:49 am     Reply with quote
Well, some of you you say that read temperature is too high.
Can someone confirm that sht75 code works fine ?
Can you post a sht75 code that works well with any PIC familly ?
+ electronic schematic ?
( Hex file would be also much appreciated )
I would like to display on a LCD, temperature and humidity.
Many thanks for your help.
Nun
PostPosted: Thu Nov 19, 2009 5:57 am     Reply with quote
Hi!
Mi sht71 sensor is giving me this temperature and humidity results. Can it be a problem of constants when it calculates the real temp &humid? or is it another problem?
T=-11.930000 & H=79.984183
T=592.229974 & H=-1185.778036
T=103.270001 & H=286.722098
T=195.430003 & H=300.089928
I used the library at the beggining of the topic, just changing the values of this function according the datasheet I downloaded from sensirion's web page
void calculate_data (int16 temp, int16 humid, float & tc, float & rhlin, float & rhtrue)
 float truehumid1, rh;
 //calculate temperature reading
 tc = ((float) temp * 0.04) - 40.1;
 //calculate Real RH reading
 rh = (float) humid;
 rhlin = (rh * 0.0367) - (rh * rh * 0.0000015955) - 2.0468;
 //calculate True RH reading
 rhtrue = ((tc - 25.0) * (0.01 + (0.00008 * rh))) + rhlin;
kizuc
LCD to use
PostPosted: Wed Nov 25, 2009 8:38 pm     Reply with quote
Thanks for the driver because I have been able to use it with 18f4550. But I have a problem with the display. Kindly recommend an LCD that can work well with this setup. Or how can I use a 7 segment display for this code ? Especially getting the driver for the 7 segment display.
jecottrell
PostPosted: Sun Feb 28, 2010 1:48 pm     Reply with quote
I know this is an old topic, but I thought I'd post for future readers...
I had a similar problem after laying out a new board and accidentally swapping the data and clock lines. Got them squared away and it works fine.
So, double check your pin defines in the driver file.
n_barroca
PostPosted: Tue Jul 13, 2010 8:07 am     Reply with quote
Hello can you send me the code you use to LCD?
Thanks.
stijn023
program
PostPosted: Tue Sep 28, 2010 4:45 am     Reply with quote
I'm using one of these sensors you used.
But my question is which c program do you used to program it?
Thanks in advance
pisisik44
PostPosted: Mon Nov 01, 2010 6:42 am     Reply with quote
Hi. If I use 16F84A at 32 KHz or 4 MHz, does it occur any problem?
Thanks for help.
atai21
PostPosted: Tue Mar 01, 2011 8:50 pm     Reply with quote
#include <18F4550.h>
#fuses HS,NOWDT,PUT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_B0,stream=ser)
#use rs232(baud=9600, xmit=PIN_B1,stream=ser1)
#include<lcd.c>
#include<sht75.c>
#byte PORTB = 0xf81
#byte PORTC = 0xf82
#define      fanA      PIN_C2
#define      fanB      PIN_C5
#define      buzzer    PIN_C6
#define      nozzle    PIN_C7
 float tempC, humidRH;
 sht_init();
printf(lcd_putc, "\b~WELCOME~ ",);
printf(lcd_putc, "\bTEMP&RH READER  ",);
  sht_rd (tempC, humidRH);
  lcd_gotoxy(1,1);
  printf(lcd_putc, "Temp : %3.1f %cC   ", tempC, 223);
  printf(lcd_putc, "\nRH   : %3.1f %%   ", humidRH);
output_high(fanA);
 if (tempC>25)
output_high(fanA);
output_high(fanB);
else if (tempC>35 && humidRH<=50)
output_high(fanA);
output_high(fanB);
else if (tempC>90 && humidRH<=15)
output_high(fanA);
output_high(fanB);
output_high(nozzle);
output_high(buzzer);
printf(lcd_putc, "WARNING!!! ",);
delay_ms(500);        //delay 500 ms between reading to prevent self heating of sensor
Hi all,
i use this code for 18f4550 and sht75.the problem is my LCD did not display anything.may i know what is wrong?
microman
pic16f877a sht75
PostPosted: Mon Apr 11, 2011 9:55 am     Reply with quote
Hey the code works initially but the temperature never increases or decreases. I checked the clock signal and there is no clock signal. I am really struggling can anybody help please.
n.b. I am using a 4mhz crystal.
The code is exactly the same as previously just changed the pin definition.
Page 2 of 3
