16F628 e2p writing problem
Invisible
PostPosted: Wed Jan 22, 2003 3:37 am     Reply with quote
hi,
just little problem with a 16F628, if I call this piece of code:
void write_e2p() {
for (i=0;i<=9;++i) {
write_eeprom(i,0x10);
printf("add: \%u=\%u,i,read_eeprom(i));
when reading e2p I got
add: 0=255
add: 1=255
...and so,
what is the problem here?, eeprom is suposed to be 10h in all that addreses..
best regards
Invisible
Original Post ID: 10884
kolio
Re: 16F628 e2p writing problem
PostPosted: Wed Jan 22, 2003 4:30 am     Reply with quote
:=hi,
:=just little problem with a 16F628, if I call this piece of code:
:=void write_e2p() {
:= for (i=0;i<=9;++i) {
:= write_eeprom(i,0x10);
:= printf("add: \%u=\%u,i,read_eeprom(i));
:=when reading e2p I got
:=add: 0=255
:=add: 1=255
:=...and so,
:=what is the problem here?, eeprom is suposed to be 10h in all that addreses..
:=best regards
:=Invisible
Oups,
in write_eeprom(i,0x10) first parameter is the value and the second is the address, so just swap their places in the souce code. It should work. It is normal that you're reading 255 - the eeprom is clear, but if you're try to read from address 0x10 there will be 9
Wish you luck!
Original Post ID: 10885
Invisible
thank you very much!!
PostPosted: Wed Jan 22, 2003 1:45 pm     Reply with quote
hi,
I just need a glases to read correctly the help file, Smile
thanks for your help!
best regards
Invisible
Original Post ID: 10894
