I2C dreaming
Renato and Davide
I2C dreaming
PostPosted: Tue Nov 13, 2001 12:02 pm     Reply with quote
Hallo !!!
We had 2 pull up 10 k resistor and then with 2.2 k resistor but the sistem did not run.
Below there are the source codes of I2C master and slave, are they correct?
******** MASTER.C ********
#include <master.h>
void i2c_master(byte slave_address, byte data_i2c)
i2c_start();
i2c_write(slave_address);
i2c_write(data_i2c);
i2c_stop();
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
enable_interrupts(global);
do {
i2c_master(0x0E, 23);
} while (TRUE);
*************** END ***********************
************ MASTER.H *********************
#include <16F877.h>
#device PIC16F877 *=16 ICD=TRUE
#use delay(clock=8000000)
#fuses HS,NOWDT,PUT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#use i2c(master,sda=PIN_C4,scl=PIN_C3, SLOW, NOFORCE_SW)
************* SLAVE.C *****************
#include <slave.h>
byte dato_i2c;
#INT_SSP
void i2c_ricevi_da_master()
if(i2c_poll()==TRUE)
dato_i2c=i2c_read();
setup_spi(FALSE);
enable_interrupts(INT_SSP);
do {} while (TRUE);
***************** END *********************
*************** SLAVE.H ********************
#include <16F877.h>
#fuses HS,NOWDT,PUT
#use I2C(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x0e, SLOW, NOFORCE_SW)
************ END **************************
Here there are the c/ASM master and slave codes:
********** MASTER *********************
CCS PCW C Compiler, Version 3.043, 11142
Filename: c:\programmi\picc\prove\i2c\master\master.LST
ROM used: 617 (8\%)
Largest free fragment is 2048
RAM used: 45 (12\%) at main() level
58 (16\%) worst case
Stack: 3 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 183
0003: NOP
.................... #include "C:\Programmi\PICC\Prove\i2c\master\master.h"
.................... #include <16F877.h>
.................... //////// Standard Header file for the PIC16F877 device ////////
.................... #device PIC16F877
.................... #list
.................... #device *=16
.................... #use delay(clock=8000000)
013E: MOVLW 48
013F: MOVWF 04
0140: BCF 03.7
0141: MOVF 00,W
0142: BTFSC 03.2
0143: GOTO 151
0144: MOVLW 02
0145: MOVWF 78
0146: CLRF 77
0147: DECFSZ 77,F
0148: GOTO 147
0149: DECFSZ 78,F
014A: GOTO 146
014B: MOVLW 97
014C: MOVWF 77
014D: DECFSZ 77,F
014E: GOTO 14D
014F: DECFSZ 00,F
0150: GOTO 144
0151: RETLW 00
.................... #fuses HS,NOWDT,PUT
.................... #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
.................... #use i2c(master,sda=PIN_C4,scl=PIN_C3)
.................... #use I2C(master, sda=PIN_C4, scl=PIN_C3, SLOW, NOFORCE_SW)
0152: BCF 14.7
0153: BCF 0C.3
0154: MOVF 49,W
0155: MOVWF 13
0156: MOVLW 02
0157: BTFSC 14.7
0158: GOTO 160
0159: BTFSS 0C.3
015A: GOTO 159
015B: MOVLW 00
015C: BSF 03.5
015D: BTFSC 11.6
015E: MOVLW 01
015F: BCF 03.5
0160: MOVWF 78
0161: RETLW 00
.................... void i2c_master(byte slave_address, byte data_i2c)
.................... i2c_start();
0162: BCF 0D.3
0163: BCF 14.7
0164: BSF 03.5
0165: BSF 11.0
0166: BCF 03.5
0167: BTFSC 0D.3
0168: GOTO 162
0169: BTFSC 14.7
016A: GOTO 162
016B: BSF 03.5
016C: BTFSS 11.0
016D: GOTO 170
016E: BCF 03.5
016F: GOTO 16B
.................... i2c_write(slave_address);
0170: BCF 03.5
0171: MOVF 47,W
0172: MOVWF 49
0173: CALL 152
.................... i2c_write(data_i2c);
0174: MOVF 48,W
0175: MOVWF 49
0176: CALL 152
.................... i2c_stop();
0177: BSF 03.5
0178: BSF 11.2
0179: BCF 03.5
017A: BSF 03.5
017B: BTFSS 11.2
017C: GOTO 17F
017D: BCF 03.5
017E: GOTO 17A
017F: BCF 03.5
0180: BCF 0A.3
0181: BCF 0A.4
0182: GOTO 25A (RETURN)
.................... void main() {
0183: CLRF 04
0184: BCF 03.7
0185: MOVLW 1F
0186: ANDWF 03,F
0187: MOVLW 9F
0188: MOVWF 04
0189: BCF 03.7
018A: MOVLW 07
018B: MOVWF 00
018C: MOVLW 0C
018D: BSF 03.5
018E: MOVWF 19
018F: MOVLW 22
0190: MOVWF 18
0191: MOVLW 90
0192: BCF 03.5
0193: MOVWF 18
0194: MOVLW FF
0195: MOVWF 20
0196: CLRF 23
0197: MOVLW 01
0198: MOVWF 24
0199: MOVLW 02
019A: MOVWF 25
019B: MOVLW 03
019C: MOVWF 26
019D: MOVLW 04
019E: MOVWF 27
019F: MOVLW 05
01A0: MOVWF 28
01A1: MOVLW 06
01A2: MOVWF 29
01A3: MOVLW 07
01A4: MOVWF 2A
01A5: MOVLW 08
01A6: MOVWF 2B
01A7: MOVLW 09
01A8: MOVWF 2C
01A9: MOVLW 0A
01AA: MOVWF 2D
01AB: MOVLW 0B
01AC: MOVWF 2E
01AD: MOVLW 0C
01AE: MOVWF 2F
01AF: MOVLW 0D
01B0: MOVWF 30
01B1: MOVLW 0E
01B2: MOVWF 31
01B3: MOVLW 0F
01B4: MOVWF 32
01B5: MOVLW 10
01B6: MOVWF 33
01B7: MOVLW 11
01B8: MOVWF 34
01B9: MOVLW 12
01BA: MOVWF 35
01BB: MOVLW 13
01BC: MOVWF 36
01BD: MOVLW 14
01BE: MOVWF 37
01BF: MOVLW 15
01C0: MOVWF 38
01C1: MOVLW 16
01C2: MOVWF 39
01C3: MOVLW 17
01C4: MOVWF 3A
01C5: MOVLW 18
01C6: MOVWF 3B
01C7: MOVLW 19
01C8: MOVWF 3C
01C9: MOVLW 1A
01CA: MOVWF 3D
01CB: MOVLW 1B
01CC: MOVWF 3E
01CD: MOVLW 1C
01CE: MOVWF 3F
01CF: MOVLW 1D
01D0: MOVWF 40
01D1: MOVLW 1E
01D2: MOVWF 41
01D3: MOVLW 1F
01D4: MOVWF 42
01D5: BCF 46.0
01D6: BCF 46.1
01D7: BCF 46.2
01D8: BSF 20.3
01D9: MOVF 20,W
01DA: BSF 03.5
01DB: MOVWF 07
01DC: BCF 03.5
01DD: BSF 20.4
01DE: MOVF 20,W
01DF: BSF 03.5
01E0: MOVWF 07
01E1: MOVLW 12
01E2: MOVWF 13
01E3: MOVLW 28
01E4: BCF 03.5
01E5: MOVWF 14
01E6: BSF 03.5
01E7: BSF 14.7
01E8: BCF 14.6
01E9: BCF 03.5
.................... setup_adc_ports(NO_ANALOGS);
01EA: MOVLW 06
01EB: BSF 03.5
01EC: MOVWF 1F
.................... setup_adc(ADC_CLOCK_DIV_2);
01ED: BCF 03.5
01EE: MOVF 1F,W
01EF: ANDLW 38
01F0: IORLW 01
01F1: MOVWF 1F
.................... setup_spi(FALSE);
01F2: BCF 14.5
01F3: BCF 20.5
01F4: MOVF 20,W
01F5: BSF 03.5
01F6: MOVWF 07
01F7: BCF 03.5
01F8: BSF 20.4
01F9: MOVF 20,W
01FA: BSF 03.5
01FB: MOVWF 07
01FC: BCF 03.5
01FD: BCF 20.3
01FE: MOVF 20,W
01FF: BSF 03.5
0200: MOVWF 07
0201: MOVLW 00
0202: BCF 03.5
0203: MOVWF 14
0204: BSF 03.5
0205: MOVWF 14
.................... setup_psp(PSP_DISABLED);
0206: BCF 09.4
.................... setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
0207: CLRF 77
0208: CLRF 77
0209: BTFSC 77.3
020A: GOTO 20D
020B: BCF 03.5
020C: GOTO 217
020D: MOVLW 07
020E: BCF 03.5
020F: CLRF 01
0210: MOVLW 81
0211: MOVWF 04
0212: BCF 03.7
0213: MOVF 00,W
0214: ANDLW C0
0215: IORLW 0F
0216: MOVWF 00
0217: CLRWDT
0218: MOVLW 81
0219: MOVWF 04
021A: MOVF 00,W
021B: ANDLW C0
021C: IORWF 77,W
021D: MOVWF 00
.................... setup_timer_1(T1_DISABLED);
021E: CLRF 10
.................... setup_timer_2(T2_DISABLED,0,1);
021F: MOVLW 00
0220: BCF 03.0
0221: RLF 00,W
0222: MOVWF 77
0223: RLF 77,F
0224: RLF 77,F
0225: MOVLW F8
0226: ANDWF 77,F
0227: MOVF 77,W
0228: MOVWF 78
0229: MOVWF 12
022A: MOVLW 00
022B: BSF 03.5
022C: MOVWF 12
.................... setup_ccp1(CCP_OFF);
022D: ANDLW F8
022E: BTFSS 03.2
022F: GOTO 233
0230: BCF 03.5
0231: BCF 07.2
0232: BSF 03.5
0233: BCF 03.5
0234: CLRF 17
0235: CLRF 17
.................... setup_ccp2(CCP_OFF);
0236: MOVLW 00
0237: ANDLW F8
0238: BTFSC 03.2
0239: BCF 07.1
023A: CLRF 1D
023B: CLRF 1D
.................... enable_interrupts(INT_SSP);
023C: BSF 03.5
023D: BSF 0C.3
.................... enable_interrupts(global);
023E: MOVLW C0
023F: BCF 03.5
0240: IORWF 0B,F
.................... do {
.................... display(1, 1, 1, 0);
0241: MOVLW 01
0242: MOVWF 47
0243: MOVWF 48
0244: MOVWF 49
0245: CLRF 4A
0246: CALL 07E
.................... delay_ms(300);
0247: MOVLW 02
0248: MOVWF 47
0249: MOVLW 96
024A: MOVWF 48
024B: CALL 13E
024C: DECFSZ 47,F
024D: GOTO 249
.................... if(input(PIN_C0)) i2c_master(0x0E, 23);
024E: BSF 20.0
024F: MOVF 20,W
0250: BSF 03.5
0251: MOVWF 07
0252: BCF 03.5
0253: BTFSS 07.0
0254: GOTO 25A
0255: MOVLW 0E
0256: MOVWF 47
0257: MOVLW 17
0258: MOVWF 48
0259: GOTO 162
.................... display(3, 3, 3, 0);
025A: MOVLW 03
025B: MOVWF 47
025C: MOVWF 48
025D: MOVWF 49
025E: CLRF 4A
025F: CALL 07E
0260: MOVLW 02
0261: MOVWF 47
0262: MOVLW 96
0263: MOVWF 48
0264: CALL 13E
0265: DECFSZ 47,F
0266: GOTO 262
.................... } while (TRUE);
0267: GOTO 241
0268: SLEEP
****************** END *******************
************** SLAVE *********************
Filename: c:\programmi\picc\prove\i2c\slave\slave.LST
ROM used: 630 (8\%)
RAM used: 54 (15\%) at main() level
68 (19\%) worst case
Stack: 4 worst case (3 in main + 1 for interrupts)
0000: NOP
0001: MOVLW 00
0002: MOVWF 0A
0003: GOTO 19A
0004: MOVWF 7F
0005: SWAPF 03,W
0006: BCF 03.5
0007: BCF 03.6
0008: MOVWF 21
0009: MOVF 0A,W
000A: MOVWF 20
000B: CLRF 0A
000C: MOVF 04,W
000D: MOVWF 22
000E: MOVF 77,W
000F: MOVWF 23
0010: MOVF 78,W
0011: MOVWF 24
0012: MOVF 79,W
0013: MOVWF 25
0014: MOVF 7A,W
0015: MOVWF 26
0016: MOVF 7B,W
0017: MOVWF 27
0018: BCF 03.7
0019: BCF 03.5
001A: MOVLW 8C
001B: MOVWF 04
001C: BTFSS 00.3
001D: GOTO 020
001E: BTFSC 0C.3
001F: GOTO 033
0020: MOVF 22,W
0021: MOVWF 04
0022: MOVF 23,W
0023: MOVWF 77
0024: MOVF 24,W
0025: MOVWF 78
0026: MOVF 25,W
0027: MOVWF 79
0028: MOVF 26,W
0029: MOVWF 7A
002A: MOVF 27,W
002B: MOVWF 7B
002C: MOVF 20,W
002D: MOVWF 0A
002E: SWAPF 21,W
002F: MOVWF 03
0030: SWAPF 7F,F
0031: SWAPF 7F,W
0032: RETFIE
0033: BCF 0A.3
0034: BCF 0A.4
0035: GOTO 036
.................... #include "C:\Programmi\PICC\Prove\i2c\slave\slave.h"
.................... #device PIC16F877 *=16 ICD=TRUE
0186: MOVLW 51
0187: MOVWF 04
0188: BCF 03.7
0189: MOVF 00,W
018A: BTFSC 03.2
018B: GOTO 199
018C: MOVLW 02
018D: MOVWF 78
018E: CLRF 77
018F: DECFSZ 77,F
0190: GOTO 18F
0191: DECFSZ 78,F
0192: GOTO 18E
0193: MOVLW 97
0194: MOVWF 77
0195: DECFSZ 77,F
0196: GOTO 195
0197: DECFSZ 00,F
0198: GOTO 18C
0199: RETLW 00
.................... #use I2C(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x0e, SLOW, NOFORCE_SW)
.................... int dato_i2c=16;
.................... #INT_SSP
.................... void i2c_ricevi_da_master()
.................... if(i2c_poll()==TRUE)
0036: MOVLW 00
0037: BSF 03.5
0038: BTFSC 14.0
0039: MOVLW 01
003A: SUBLW 01
003B: BTFSC 03.2
003C: GOTO 03F
003D: BCF 03.5
003E: GOTO 048
003F: BCF 03.5
.................... dato_i2c=i2c_read();
0040: BSF 03.5
0041: BTFSC 14.0
0042: GOTO 045
0043: BCF 03.5
0044: GOTO 040
0045: BCF 03.5
0046: MOVF 13,W
0047: MOVWF 4F
0048: BCF 0C.3
0049: BCF 0A.3
004A: BCF 0A.4
004B: GOTO 020
019A: CLRF 04
019B: BCF 03.7
019C: MOVLW 1F
019D: ANDWF 03,F
019E: MOVLW 9F
019F: MOVWF 04
01A0: BCF 03.7
01A1: MOVLW 07
01A2: MOVWF 00
01A3: MOVLW 0C
01A4: BSF 03.5
01A5: MOVWF 19
01A6: MOVLW 22
01A7: MOVWF 18
01A8: MOVLW 90
01A9: BCF 03.5
01AA: MOVWF 18
01AB: MOVLW FF
01AC: MOVWF 28
01AD: BSF 28.3
01AE: MOVF 28,W
01AF: BSF 03.5
01B0: MOVWF 07
01B1: BCF 03.5
01B2: BSF 28.4
01B3: MOVF 28,W
01B4: BSF 03.5
01B5: MOVWF 07
01B6: MOVLW 0E
01B7: MOVWF 13
01B8: MOVLW 36
01B9: BCF 03.5
01BA: MOVWF 14
01BB: CLRF 2B
01BC: MOVLW 01
01BD: MOVWF 2C
01BE: MOVLW 02
01BF: MOVWF 2D
01C0: MOVLW 03
01C1: MOVWF 2E
01C2: MOVLW 04
01C3: MOVWF 2F
01C4: MOVLW 05
01C5: MOVWF 30
01C6: MOVLW 06
01C7: MOVWF 31
01C8: MOVLW 07
01C9: MOVWF 32
01CA: MOVLW 08
01CB: MOVWF 33
01CC: MOVLW 09
01CD: MOVWF 34
01CE: MOVLW 0A
01CF: MOVWF 35
01D0: MOVLW 0B
01D1: MOVWF 36
01D2: MOVLW 0C
01D3: MOVWF 37
01D4: MOVLW 0D
01D5: MOVWF 38
01D6: MOVLW 0E
01D7: MOVWF 39
01D8: MOVLW 0F
01D9: MOVWF 3A
01DA: MOVLW 10
01DB: MOVWF 3B
01DC: MOVLW 11
01DD: MOVWF 3C
01DE: MOVLW 12
01DF: MOVWF 3D
01E0: MOVLW 13
01E1: MOVWF 3E
01E2: MOVLW 14
01E3: MOVWF 3F
01E4: MOVLW 15
01E5: MOVWF 40
01E6: MOVLW 16
01E7: MOVWF 41
01E8: MOVLW 17
01E9: MOVWF 42
01EA: MOVLW 18
01EB: MOVWF 43
01EC: MOVLW 19
01ED: MOVWF 44
01EE: MOVLW 1A
01EF: MOVWF 45
01F0: MOVLW 1B
01F1: MOVWF 46
01F2: MOVLW 1C
01F3: MOVWF 47
01F4: MOVLW 1D
01F5: MOVWF 48
01F6: MOVLW 1E
01F7: MOVWF 49
01F8: MOVLW 1F
01F9: MOVWF 4A
01FA: BCF 4E.0
01FB: BCF 4E.1
01FC: BCF 4E.2
01FD: MOVLW 10
01FE: MOVWF 4F
01FF: MOVLW 06
0200: BSF 03.5
0201: MOVWF 1F
0202: BCF 03.5
0203: MOVF 1F,W
0204: ANDLW 38
0205: IORLW 01
0206: MOVWF 1F
0207: BCF 14.5
0208: BCF 28.5
0209: MOVF 28,W
020A: BSF 03.5
020B: MOVWF 07
020C: BCF 03.5
020D: BSF 28.4
020E: MOVF 28,W
020F: BSF 03.5
0210: MOVWF 07
0211: BCF 03.5
0212: BCF 28.3
0213: MOVF 28,W
0214: BSF 03.5
0215: MOVWF 07
0216: MOVLW 00
0217: BCF 03.5
0218: MOVWF 14
0219: BSF 03.5
021A: MOVWF 14
021B: BCF 09.4
021C: CLRF 77
021D: CLRF 77
021E: BTFSC 77.3
021F: GOTO 222
0220: BCF 03.5
0221: GOTO 22C
0222: MOVLW 07
0223: BCF 03.5
0224: CLRF 01
0225: MOVLW 81
0226: MOVWF 04
0227: BCF 03.7
0228: MOVF 00,W
0229: ANDLW C0
022A: IORLW 0F
022B: MOVWF 00
022C: CLRWDT
022D: MOVLW 81
022E: MOVWF 04
022F: MOVF 00,W
0230: ANDLW C0
0231: IORWF 77,W
0232: MOVWF 00
0233: CLRF 10
0234: MOVLW 00
0235: BCF 03.0
0236: RLF 00,W
0237: MOVWF 77
0238: RLF 77,F
0239: RLF 77,F
023A: MOVLW F8
023B: ANDWF 77,F
023C: MOVF 77,W
023D: MOVWF 78
023E: MOVWF 12
023F: MOVLW 00
0240: BSF 03.5
0241: MOVWF 12
0242: ANDLW F8
0243: BTFSS 03.2
0244: GOTO 248
0245: BCF 03.5
0246: BCF 07.2
0247: BSF 03.5
0248: BCF 03.5
0249: CLRF 17
024A: CLRF 17
024B: MOVLW 00
024C: ANDLW F8
024D: BTFSC 03.2
024E: BCF 07.1
024F: CLRF 1D
0250: CLRF 1D
0251: BSF 03.5
0252: BSF 0C.3
0253: MOVLW C0
0254: BCF 03.5
0255: IORWF 0B,F
.................... dato_i2c=16;
0256: MOVLW 10
0257: MOVWF 4F
.................... display(dato_i2c, 1, 1, 0);
0258: MOVF 4F,W
0259: MOVWF 50
025A: MOVLW 01
025B: MOVWF 51
025C: MOVWF 52
025D: CLRF 53
025E: CALL 0C6
025F: MOVLW 02
0260: MOVWF 50
0261: MOVLW 96
0262: MOVWF 51
0263: CALL 186
0264: DECFSZ 50,F
0265: GOTO 261
.................... display(dato_i2c, 3, 3, 0);
0266: MOVF 4F,W
0267: MOVWF 50
0268: MOVLW 03
0269: MOVWF 51
026A: MOVWF 52
026B: CLRF 53
026C: CALL 0C6
026D: MOVLW 02
026E: MOVWF 50
026F: MOVLW 96
0270: MOVWF 51
0271: CALL 186
0272: DECFSZ 50,F
0273: GOTO 26F
0274: GOTO 258
0275: SLEEP
****************** END ********************
IDE Version = 2.32
PCB Version = 3.043
PCM Version = 3.043
Thank you for the support. Best regards
Original Post ID: 1085
Tomi
Re: I2C dreaming
PostPosted: Tue Nov 13, 2001 12:44 pm     Reply with quote
I have had a quick view on your code.
Your PICs are in Low Voltage Programming Mode. Probably the PIC is waiting for programming signals.
Insert the NOLVP keyword into the #fuses directive, e.g.
#fuses HS,NOWDT,PUT, NOLVP
Another problem:
The SPI and the I2C HW is common, so your line:
setup_spi(FALSE);
will disable the I2C hardware:
0216: MOVLW 00 // load NULL
0217: BCF 03.5
0218: MOVWF 14 // move to SSPCON
BTW, here are the lines to init the slave IIC you are looking for:
01B8: MOVLW 36 // as I wrote in previous post
01B9: BCF 03.5
01BA: MOVWF 14 // move to SSPCON
But, once more, your setup_spi(FALSE) call will overwrite this correct setting.
Additionally, the rest of your init lines at the top of the main() is unnecessary. PLEASE, see and read the "ex_slave.c" example! You can use it as a good base code to find out a "to do list".
In your case only the
is necessary (the default state of these pins are analog after startup).
Why write setup_adc(ADC_CLOCK_DIV_2) if no analog pins?
PSP, counters, CCP are disabled at startup.
Hope this helps.
Brg,
Tomi
Original Post ID: 1087
