CCP1 Capture Interrupt Latency (18F452)
Goto page Previous  1, 2
Flowmeter
Syntax error
PostPosted: Tue Oct 29, 2013 1:45 am     Reply with quote
Thank you very much for your reply.
When I change the line to the suggested code
#define BytePtr(var, offset) (&(char)var + offset))
I receive a syntax error e.g. for this line
*BytePtr(test0,0)=addOn;
Do I also need to change something in this line?!
Thank you already so much for your help.
PostPosted: Tue Oct 29, 2013 1:57 am     Reply with quote
This test program compiles with no errors with vs. 5.013:
#include <18F67J50.h>
#fuses INTRC_IO,NOWDT
#use delay(clock=4M)
INT32 test0 = 0x0000ff00;
INT32 test1 = 0x0000ff00;
INT32 test2 = 0x0000ff00;
INT32 test3 = 0x0000ff00;
INT8 addOn=0x0f;
*BytePtr(test1,1)=addOn;
*BytePtr(test2,2)=addOn;
*BytePtr(test3,3)=addOn;
printf("%lx \r", test0);
printf("%lx \r", test1);
printf("%lx \r", test2);
printf("%lx \r", test3);
This is from the MPLAB output window:
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Tue Oct 29 00:51:36 2013
Your post says you're using C18. I disregarded that because you're
declaring your variables with CCS style data types, such as int8 and int32.
If you're actually using C18, we can't help you. This is a CCS forum.
The place to ask would be on the microchip.com C18 forum.
If you are using CCS, then post your version.
Flowmeter
PostPosted: Tue Oct 29, 2013 2:03 am     Reply with quote
Thank you for your answer. So I try to get an answer from MicroChip and if not I will have to switch to CCS Smile
Thanks again.
By the way changing it to:
#define BytePtr(var, offset) ((char*)&var + offset)
was the solution.
Page 2 of 2
