PIC16F818 And #fuses WDT
SlavaZ
PostPosted: Thu Apr 02, 2009 10:00 am     Reply with quote
I'm setting
#fuses WDT
but the hex file invariably has WDT disabled. I had to manually override it in MPLAB IDE to enable WDT. That's not the way to go. Is there any other way to specify config bit in the source file?
All other fuses that I use do have effect:
#fuses WDT,NOPUT,INTRC,MCLR
just not the WDT
Any suggestions?
PostPosted: Thu Apr 02, 2009 12:00 pm     Reply with quote
WDT is automatically disabled by the compiler if you are in Debug mode.
Debugging with WDT enabled is not supported.
http://www.ccsinfo.com/forum/viewtopic.php?t=36293&start=1
If you still have problems then,
1. Post a very short (but complete) test program that shows the problem.
The posted code must be able to be pasted into MPLAB and then compile
with no errors.
2. Post your compiler version.
