access violations
dave.t
access violations
PostPosted: Thu Jan 16, 2003 11:27 am     Reply with quote
Many thanks for all your replies on the above topic.
I am running windows 98.
When I load a file it sometimes happens,when it does happen when first opening a file I cannot use the scroll bar to move through the file. If I close the file down and reopen it, It usually works fine!
Very odd!
Thanks again
Dave
Original Post ID: 10739
kolio
Re: access violations
PostPosted: Fri Jan 17, 2003 5:30 am     Reply with quote
:=Many thanks for all your replies on the above topic.
:=I am running windows 98.
:=When I load a file it sometimes happens,when it does happen when first opening a file I cannot use the scroll bar to move through the file. If I close the file down and reopen it, It usually works fine!
:=Very odd!
:=Thanks again
:=Dave
Aha,
so it's an IDE problem. I would describe it the same way, plus "Compile" button is gray and becomes an inactive. Even somethimes you can't close the application in the normal way, but should do it via "End Task". Don't worry, buy newer version of PSW, more RAM and change OS ;-)
Seriously, even one of those things will improve the situation.
Best of all is to change PSW.
Good luck!
Original Post ID: 10748
