		| Author | Message |
		| PeterD Guest
				| inttoascii or hextoascii function? |
				|  Posted: Mon Dec 16, 2002 9:17 am |   |
				| Does anyone know where I can find an inttoascii or hextoascii function? ___________________________
 Original Post ID: 10065
		| R.J.Hamlett Guest
				| Re: inttoascii or hextoascii function? |
				|  Posted: Mon Dec 16, 2002 9:43 am |   |
				| :=Does anyone know where I can find an inttoascii or hextoascii function?
 sprintf
 For your requirements:
 char output[5];
 sprintf(output,"\%D",value_to_convert);
 Will put into the string 'output', the ASCII equivalent of the number in 'value_to_convert'. Using '\%ld', instead of '\%D', will allow a long integer to be sent. With this the output could be seven digits 'wide' ('-' sign, 5 digits, and the terminating '\0'), so the array would need to be larger.
 Original Post ID: 10066
		| Dave Yeatman Guest
				|  Posted: Mon Dec 16, 2002 4:07 pm |   |
				| Depending on what you are doing, converting individual numbers is easy. This would be the building block for whatever you want to do.
 If a decimal digit simply add 48 to make it the ascii equivalent.
 For hex:
 If <=9 then add 0x30, else add 0x37.
 I created a function that I call with the digit to convert and it returns a char.  I also pass a boolean flag "hex" to tell whether to convert hex or decimal. Once created, the routine works everywhere and you can paste it into any code.
 Example protoype:
 char convert(byte digit, boolean hex)
 Good Luck!
 Dave
 Original Post ID: 10078
 | You cannot post new topics in this forum You cannot reply to topics in this forum
