Has anyone ported MC TCP/IP stack to CCS ?
Hans Wedemeyer
PostPosted: Mon Aug 04, 2003 7:46 pm     Reply with quote
Has anyone ported the MicroChip TCP/IP stack to CCS ?
Another question: I'm looking for a simple FTP client using a dial up connection. Anyone know of any code example for CCS or that can be ported ?
Hans W
Original Post ID: 144516665
Darren Rook
Re: Has anyone ported MC TCP/IP stack to CCS ?
PostPosted: Tue Aug 05, 2003 7:46 am     Reply with quote
:=Has anyone ported the MicroChip TCP/IP stack to CCS ?
:=Another question: I'm looking for a simple FTP client using a dial up connection. Anyone know of any code example for CCS or that can be ported ?
Yes.
I also added PPP to it, although not perfect now.
I didn't port over the file system, SLIP, HTTP server (mostly due to pointers to constants. I got it to compile, but didn't bother to use them)... Only the actual TCP/IP stack I ported and used.
I believe if you ask CCS nicely you can get a copy.
Original Post ID: 144516672
I came, I saw, I compiled.
Hans Wedemeyer
PostPosted: Tue Aug 05, 2003 9:12 am     Reply with quote
:=I believe if you ask CCS nicely you can get a copy.
Please with sprinkles on top.... :-)
Original Post ID: 144516680
Gerrit
PostPosted: Tue Aug 05, 2003 2:08 pm     Reply with quote
Hello Darren,
I am also reading and looking if I can port TCP/IP stack from
microchip.
Could you send me also a copy of the modified microchip
TCP/IP stack etc.
gerrit@rc-engineering.nl
Best regards,
Gerrit
:=:=Has anyone ported the MicroChip TCP/IP stack to CCS ?
:=:=Another question: I'm looking for a simple FTP client using a dial up connection. Anyone know of any code example for CCS or that can be ported ?
:=Yes.
:=I also added PPP to it, although not perfect now.
:=I didn't port over the file system, SLIP, HTTP server (mostly due to pointers to constants. I got it to compile, but didn't bother to use them)... Only the actual TCP/IP stack I ported and used.
Original Post ID: 144516684
Hans Wedemeyer
PostPosted: Tue Aug 05, 2003 2:25 pm     Reply with quote
:=gerrit@rc-engineering.nl
But you did not say please...
As there is no word for Please in Dutch you may be forgiven...
Original Post ID: 144516685
Gerrit
PostPosted: Tue Aug 05, 2003 5:53 pm     Reply with quote
There is
alstublieft
Gerrit
:=:=gerrit@rc-engineering.nl
:=But you did not say please...
:=As there is no word for Please in Dutch you may be forgiven...
Original Post ID: 144516695
Hans Wedemeyer
PostPosted: Tue Aug 05, 2003 8:32 pm     Reply with quote
Yes... now I remember... It's the Norwegians that do not have Please in their language...
Original Post ID: 144516698
PicFan
PostPosted: Thu Aug 07, 2003 6:56 am     Reply with quote
:=Yes.
Darren - What is the appropriate avenue to "ask CCS nicely"? (via email? - telephone call?)
best regards,
PicFan
Original Post ID: 144516772
SBK
TCP/IP & PPP For CCS
PostPosted: Sat Dec 20, 2003 9:00 am     Reply with quote
May I try your TCP/IP and PPP implementation for CCS C Compiler?
Does it use an usual modem or a special embedded modem?
Could you send it to my email please : sobakava1@hotmail.com
Best Regards
