john cutler
Joined: 06 Sep 2003 Posts: 82 Location: Hot Tub, California
| LCD multiple Bar Graph Display |
Posted: Wed Jul 16, 2003 4:18 pm |
Does anyone have any recommendations for a small LCD display that could display 8 or 10 vertical low resolution bar graphs?
It needs to work in darkness with a backlight and also outside in sunlight. The resolution is not especially critical - it just needs to show relative control settings of audio levels, not actual audio. Consequently, it doesn't need really fast updates. It needs to be serially addressed - SPI or I2C.
I'd appreciate being steered in a good direction since I've never messed with LCD's before.
Thanks!
JC
___________________________
Original Post ID: 144516079 |
pez Guest
| Re: LCD multiple Bar Graph Display |
Posted: Wed Jul 16, 2003 9:32 pm |
<a href="http://www.powertip.com.tw/product/pro_char.asp" TARGET="_blank">http://www.powertip.com.tw/product/pro_char.asp</a>
look at the one below or others to your liking.
it's compatable with the driver suplied with the compiler
PC1604-A
COB
87.0x60.0
56.20x20.80
2.95x4.75
3.55x5.35
S6A0069X*
1/16-1/4
None, EL, LED
TN, STN
enjoy
PEZ
:=Does anyone have any recommendations for a small LCD display that could display 8 or 10 vertical low resolution bar graphs?
:=It needs to work in darkness with a backlight and also outside in sunlight. The resolution is not especially critical - it just needs to show relative control settings of audio levels, not actual audio. Consequently, it doesn't need really fast updates. It needs to be serially addressed - SPI or I2C.
:=I'd appreciate being steered in a good direction since I've never messed with LCD's before.
:=Thanks!
:=JC
Original Post ID: 144516084 |
