The very first interrupt.
PCM Novice
PostPosted: Thu Jan 09, 2003 7:01 am     Reply with quote
<font face="Courier New" size=-1>I am trying to time an asynchronous event using timer2. I want the event to call enble_interrupts to start the measurement, rather than keeping the interrupt going and using set_timer2(0) to initiate it (see code fragment below).
But the call to enable_interrupts causes an imediate interrupt, has anyone any ideas?
setup_timer_2(T2_DIV_BY_16,200,5);
// timer set to 5.2ms with 12.288 MHz xtal
// some event
set_timer2(0);
// I would expect first interrupt 5.2ms later.. But it happens imedeately.
//Interrupts there after occur correctly at 5.2ms intervals as expected.
</font>
Original Post ID: 10557
PCM Novice
Re: The very first interrupt. Solved!
PostPosted: Thu Jan 09, 2003 8:45 am     Reply with quote
Solved using
set_timer2(0);
#asm
BCF PIR1, TMR2IF // clear the timer 2 interrupt flag
#endasm
:=<font face="Courier New" size=-1>I am trying to time an asynchronous event using timer2. I want the event to call enble_interrupts to start the measurement, rather than keeping the interrupt going and using set_timer2(0) to initiate it (see code fragment below).
:=But the call to enable_interrupts causes an imediate interrupt, has anyone any ideas?
:=setup_timer_2(T2_DIV_BY_16,200,5);
:=// timer set to 5.2ms with 12.288 MHz xtal
:=// some event
:=set_timer2(0);
:=enable_interrupts(INT_TIMER2);
:=// I would expect first interrupt 5.2ms later.. But it happens imedeately.
:=//Interrupts there after occur correctly at 5.2ms intervals as expected.
:=</font>
Original Post ID: 10563
