Can PIC18F26K40 (28 pin device) support 2 UARTS
DaveMorris
PostPosted: Thu Jul 03, 2025 10:08 am     Reply with quote
Hi
Can someone please confirm if the 18F26K40 support 2 UART - The data sheet is a little confusing as it suggest its supports two EUSARTs but in the pin allocation table for the 28 pin devices it only shows TX1 , RX1 etc and no reference to TX2 or RX1 - Unless obviously I am miss reading the tables
Thanks in advance
Dave
PostPosted: Thu Jul 03, 2025 1:10 pm     Reply with quote
It looks like to me you have to PPS assign TX2 and RX2 somewhere to
use them since they don't show in the pin map. They are both defined
in the header file and chip editor so I would try it to see what happens.
Be sure to turn of any other function on the pins you select..that's
bitten me a couple of times.
PostPosted: Thu Jul 03, 2025 2:43 pm     Reply with quote
from the data sheet(took a bit...)...
The RXx/DTx and TXx/CKx input pins are selected with the RXxPPS and TXxPPS registers,
respectively. TXx, CKx, and DTx output pins are selected with each pin’s RxyPPS register.
dang nab 'new chip' to me , has PPS !
