How to use free ram space in ds1307
arge
PostPosted: Tue Sep 24, 2024 5:45 am     Reply with quote
Hello everyone. How to use free ram space in ds1307?. Can you give a code example in css language.
Software. Hardware. Research. Learning
dyeatman
PostPosted: Tue Sep 24, 2024 7:25 am     Reply with quote
The CCS drivers DS1302.c and DS1305.c should give you some idea.
Also, a search here for DS1307 gives a lot of info.
Google and Forum Search are some of your best tools!!!!
arge
PostPosted: Tue Sep 24, 2024 9:43 am     Reply with quote
I searched but couldn't find it. If you know, could you send me a link?
dyeatman
PostPosted: Tue Sep 24, 2024 11:00 am     Reply with quote
If you have the CCS software the .c files are in the PICC/Drivers directory.
If you are not a registered user I can't provide you the files due to copyright.
Also a forum search gives a great deal of info...don't know why you can't find it.
BTW, this is CCS PICC not CSS or Code Composer so you may have the wrong forum.
arge
PostPosted: Tue Sep 24, 2024 12:39 pm     Reply with quote
///////////////////// TEST CODE ////////////////////////////////////////////////////
void ds1307_REGISTER_WRITE(BYTE REG8, BYTE REG9, BYTE REG10)
  i2c_start();
  i2c_write(0xD0);            // I2C write address
  i2c_write(0x08);            // Start at REG 8
  i2c_write(bin2bcd(REG8));    // REG 8
  i2c_write(bin2bcd(REG9));    // REG 9
  i2c_write(bin2bcd(REG10));   // REG 10
  i2c_stop();
void ds1307_REGISTER_READ(BYTE &REG8, BYTE &REG9, BYTE &REG10)
  i2c_start();
  i2c_write(0xD0);
  i2c_start();
  i2c_write(0xD1);
  REG8 =  bcd2bin(i2c_read());
  REG9 =  bcd2bin(i2c_read());
  REG10=  bcd2bin(i2c_read());
  i2c_stop();
////////////////////////TEST CODE /////////////////////////////////////////////
arge
PostPosted: Tue Sep 24, 2024 4:09 pm     Reply with quote
I updated. We can save and read values ​​between 0-255.
void ds1307_REGISTER_WRITE(int16 REG8, int16 REG9, int16 REG10)
  i2c_start();
  i2c_write(REG8);   // REG 8
  i2c_write(REG9);   // REG 9
  i2c_write(REG10);  // REG 10
  i2c_stop();
void ds1307_REGISTER_READ(int16 &REG8, int16 &REG9, int16 &REG10)
  i2c_start();
  i2c_start();
  i2c_write(0xD1);
  REG8 = i2c_read();  // REG 8
  REG9 = i2c_read();  // REG 9
  REG10= i2c_read();  // REG 10
  i2c_stop();
arge
PostPosted: Tue Sep 24, 2024 6:20 pm     Reply with quote
//ds1307_REGISTER_WRITE(adress,data);
//data=ds1307_REGISTER_READ(adress);
void ds1307_REGISTER_WRITE(unsigned int16 ds1302_adres, unsigned int16 ds1302_data)
  i2c_start();
  i2c_write(0xD0);        // chip address
  i2c_write(ds1302_adres);// Write to this numbered register
  i2c_write(ds1302_data); // data
  i2c_stop();
  delay_ms(50);
BYTE ds1307_REGISTER_READ(unsigned int16 DS_address)
   BYTE ds1302_data;
   i2c_start();
   i2c_write(DS_address);// read this numbered register
   i2c_start();
   i2c_write(0xD1);
   ds1302_data = i2c_read(0);
   i2c_stop();
   delay_ms(50);
   return(ds1302_data);
