PIC16F18877 and A6 / A7 [Solved]
Birepo
PostPosted: Thu Mar 16, 2023 7:15 am     Reply with quote
I am using PIC16F18877 and A6 and A7 is not works.
Is there a trick to make these 2 ports act as output?
This is set:
#fuses NOEXTOSC              //External Oscillator not enabled
#fuses RSTOSC_HFINTRC_32MHZ  //On Power-up clock running from HFINTRC at 32 MHz
#fuses HS                    //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#fuses CKS                   //Clock Switching Enabled
#fuses FCMEN                 //Fail-safe clock monitor enabled
#fuses LPBOR                 //Low-Power Brownout reset is enabled
#fuses BORV27                //Brownout reset at 2.7V
#fuses STVREN                //Stack full/underflow will cause reset
#fuses WDTCLK_HFINTRC        //WDT uses 31.25 kHz HFINTRC as clock source
#fuses WDT                   //Watch Dog Timer
#fuses WDTSW                 //Watch Dog Timer Postscale settable in software
#fuses WDTWIN_100%           //Watchdog Window is 100% of WDT period
#fuses WDT32768              //Watch Dog Timer uses 1:32768 Postscale
#fuses NOWRT                 //Program memory not write protected
#fuses NOLVP                 //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#fuses NOCLKOUT              //I/O function on OSC2
#fuses MCLR                  //Master Clear pin enabled
#fuses PPS1WAY               //Allows only one reconfiguration of peripheral pins
#fuses PUT                   //Power Up Timer
#fuses NOSCANE               //Scanner module is not available for use
#use fixed_IO(A_outputs = PIN_A0,PIN_A1,PIN_A2,PIN_A6,PIN_A7)
Birepo
PostPosted: Thu Mar 16, 2023 7:17 am     Reply with quote
I am using PCWHD Compiler V5.115
Birepo
PostPosted: Thu Mar 16, 2023 7:43 am     Reply with quote
This was the error
//#fuses HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
Do not use HS
