PIC16F15223 stops functioning for no apparent reason
randy.shaffer
PostPosted: Fri Feb 03, 2023 3:06 pm     Reply with quote
#include <16F15223.h> // device file
#include <stdint.h> // to use uint16_t, etc.
#fuses PUT_16MS, NOWDT
#device adc = 10 // 10-bit A2D
#use delay(internal = 32MHZ)
#use pwm(FREQUENCY = 31.25kHz, PWM_OFF, STREAM = IN1, output=PIN_A4)
#use pwm(FREQUENCY = 31.25kHz, PWM_OFF, STREAM = IN2, output=PIN_A5)
 uint16_t HALL_VALUE = 0;
 set_tris_a(0b00001011); // X: A7,A6. Inputs: A3,A1,A0. Outputs: A5,A4,A2.
 set_tris_c(0b00001100); // X: C7,C6. Inputs: C3,C2. Outputs: C5,C4,C1,C0.
 setup_vref(VREF_ON|VREF_ADC_2v048); // Set Vref = 2.048 V for ADC
 setup_adc(ADC_CLOCK_DIV_32); // ADC clock = 32/32 = 1 MHz
 setup_adc_ports(sAN18 | sAN19, VSS_FVR); // ADC channel 18 using Vref
  PWM_set_duty_percent(IN2, FALSE); // IN2 = 0
  PWM_on(IN2);
  PWM_set_duty_percent(IN1, 500);
  PWM_on(IN1); // IN1 = PWM
  while(HALL_VALUE < 350)
  {// move inhibitor away from motor until unlock limit exceeded
   set_adc_channel(18); // enable selected channel
   delay_us(10); // wait 10us for ADC to settle
   HALL_VALUE = read_adc(); // get ADC value
  PWM_off(IN1); // IN1 = 0
  PWM_off(IN2); // IN2 = 0
  delay_ms(2000);
  PWM_set_duty_percent(IN1, FALSE); // IN1 = 0
  PWM_on(IN1);
  PWM_set_duty_percent(IN2, 500);
  PWM_on(IN2); // IN2 = PWM
  while(HALL_VALUE > 25)
  {// move inhibitor toward motor
  delay_ms(2000);
} // end main
After running properly for a while, sometimes a short while, the PIC hangs up and I have to cycle power to restart. If I try to re-program after a hang up, it will not start up. Am I missing an important fuse? Compiler is 5.114. PIC is a 16-QFN.
gaugeguy
PostPosted: Fri Feb 03, 2023 3:38 pm     Reply with quote
Your notes mention a motor so I am going to go with conductor and/or radiated EMI.
PostPosted: Fri Feb 03, 2023 3:53 pm     Reply with quote
as gg says, probably EMO from motor...
does the program work 'forever' if motor power is disconnected ?
randy.shaffer
PostPosted: Fri Feb 03, 2023 4:05 pm     Reply with quote
I'll disconnect the motor and see. Thank you both for the advice.
