PIC not running after programming
Jody
PostPosted: Thu Jan 26, 2023 7:04 am     Reply with quote
(PIC18f87J50 , ICD3 ,CCS 5.080)
What I have..
With the debugger attached (in debug mode) and running the program it is working.
LED's are flashing LCD is used etc...
Switching to release and use the ICD3 as a programmer then the program doesn't run any more...
I switched the clock.. used the innternal etc..
enabled fuses .. disabled fuses but no luck..
anybody an idea???
Best regards,
Jody
PrinceNai
PostPosted: Thu Jan 26, 2023 7:21 am     Reply with quote
You do have a resistor on MCLR to 5V?
Jody
PostPosted: Thu Jan 26, 2023 7:29 am     Reply with quote
Yes I have...
Jody
PostPosted: Thu Jan 26, 2023 7:40 am     Reply with quote
FIXED IT!!!
Stupid me has soldered only one side of the pullup resistor!!!!
Thanks!!!
PrinceNai
PostPosted: Thu Jan 26, 2023 7:50 am     Reply with quote
I don't know what environment you are using. MPLABX? There are some options to hold a device in reset. Maybe that is a problem? I never had a problem with that, but some here have said that if you leave #device ICD = TRUE or #fuses debug (don't know which) in your code, the program doesn't run.
