asp142r
| Output window not show |
Posted: Thu Sep 09, 2021 12:16 am |
Hello.
I'm using PCWHD Compiler v5.104.
When I use C-aware IDE, I have some trouble with window.
The output window (The showed window when your code has some error and warning) does not show on desktop.
When I see it at first, I tried some way below, but in vain.
-Click Output(checkbox) in view tab.
-Erase registry data and Re-install Compiler.
I think resetting IDE setting may solve my problem. (It may reset output window's position). Could you tell me how to reset it? or If you have better way to solve this problem, could you teach me, too? |
