const char pointer problem
Raul
PostPosted: Wed Jan 08, 2003 2:48 pm     Reply with quote
I'm writing a driver for a custom display which uses a menu system. I defining my text library I decided to use constant character arrays for my text. I then attempt to point to the individual characters for the printing of text. I am using version 3.129 of the compiler and am programming for a PIC18F6720. Here is what I am having problems with.
// In the header file
const char test1[] = "TEST";
void Print_String(const char *ch);
// In function library
int8 x = 0;
while(ch[x] != NULL)
w_data = (int)ch[x];
wr_data(); // Sends data to display
x++;
// Somewhere in code
Print_String(test1);
Now when I try to compile, the compiler stops when it gets to my function declaration, more specifically at the 'char' declaration and I get a message that says 'Expecting a , or )'. I've used this method with a couple other compilers and one being Microchips C17 and it worked fine. Is there a fix or some work around for this?
Original Post ID: 10543
Re: const char pointer problem
PostPosted: Wed Jan 08, 2003 3:08 pm     Reply with quote
:=I'm writing a driver for a custom display which uses a menu system. I defining my text library I decided to use constant character arrays for my text. I then attempt to point to the individual characters for the printing of text.
CCS doesn't allow pointers to constant strings.
If you want to pass a pointer, you first have
to copy the string into a ram array by using
the strcpy() function.
But you can still use constant strings.
The following program shows how you could
send the string to an RS-232 terminal, or
to an LCD.
Also, the printf() function can have its
output redirected to another function.
See the manual for info on this.
#include "c:\program files\picc\devices\16F877.h"
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
#include <lcd.c>
printf(test1);
lcd_putc(test1);
while(1); // Prevent PIC from going to sleep
Original Post ID: 10544
johnpcunningham
PostPosted: Wed Jan 08, 2003 3:09 pm     Reply with quote
This compiler does not allow pointers to constants. You can use an addressing mode to send the characters.
EXAMPLE:
const char line_1[] ="my data";
char i = 0;
while( i != sizeof(line_1)
write_data(line_1[i++]);
Original Post ID: 10545
