jaka
Posted: Sat Nov 28, 2020 7:04 am |
This is clever solution to the problem.
The root cause of problem is that the RE3 pin doesn't have the internal ESD protection diode clamp to VDD, like all other pins have. This is because the RE3 pin must be able to swing to Vpp to enter programming mode.
If you have a positive voltage transient on RE3 pin, the pin voltage will rise to Vpp, which causes the PIC to reset. The diode you added prevents the positive transients propagating to pin.
However, if you have high voltage transients like ESD, they can 'shoot through' the 1N4148. This could be avoided by adding external clamp diode from RE3 to VDD (anode to RE3, cathode to VDD). BUT adding this clamp diode prevents you from programming the PIC in high voltage programming mode!
I have found that the best solution is to avoid using the /MCLR pin for other purposes than reset or programming. Especially when it is routed far away from the PIC or when it is possible to touch it. It also helps to put 10 nF cap on the MCLR pin, which prevents PIC from reseting if you touch the programming connector. Even though Microchip suggests to not place any caps on the line. |
vtrx
Posted: Sat Nov 28, 2020 9:30 am |
Anyway, i discovered this 'too late', as i already have 20 pcb ready without components.
I will have to order again with the modification or risk leaving it as is. |
Posted: Sat Nov 28, 2020 11:41 am |
This is why if you use the pin for something like this it is worth having
jumper enabled protection. |
Joined: 01 Jul 2010 Posts: 9108 Location: Greensville,Ontario
Posted: Sat Nov 28, 2020 11:46 am |
I decided a few years ago to have the ICSP pins DEDICATED to ICSP having been stumped for days wondering 'it should work' only to discover the 'unique' trouble I was having...grrr...
if I need extra pins, a simple 'expander' is cheap and easy to add on... |
