L.T.
Posted: Thu Aug 13, 2020 3:04 am |
Thank for your time and sorry for my ignorance. I need your help. I tried everything but I failed. :( |
OK. No guarantees on this, but this covers most of the problems with
what has been posted:
#include <16F18346.h>
#device ADC=10
#use delay(internal=16000000)
//setup softwarew SPI so bit order can be reversed.
#use spi(DI=PIN_B4, DO=PIN_C7, CLK=PIN_B6, LSB_FIRST, baud=1000000, MODE=2, stream=PGA)
#PIN_SELECT U1TX=PIN_A1
#PIN_SELECT U1RX=PIN_A0 //basic UART setup for diagnostics
#use RS232(UART1, baud=9600, ERRORS)
// Define commands by name
#define P1BL 0x00
#define P2BL 0x01
#define P1LO 0x02
#define P2LO 0x03
#define TNLM 0x04
#define UMR 0x05
#define TNLR 0x06
#define TEDD 0x07
#define SD 0x08
#define SRR 0x09
#define SRW 0x0A
#define EEBR 0x0B
#define EEBW 0x0C
#define TVGBR 0x0D
#define TVGBW 0x0E
#define THRBR 0x0F
#define THRBW 0x10
#define syncByte 0x55
int numObj=1;
unsigned int objTime[8];
byte ultraMeasResult[36]; //buffer for results
/*------------------------------------------------- calcChecksum -----
| Function calcChecksum
| Purpose: Calculates the UART checksum value for n bytes in the buffer
| Parameters:
| Number of bytes
| Returns: byte representation of calculated checksum value
int checksum(char * buffer, int number)
unsigned int16 sum=0;
unsigned int8 ctr=1; //ignore 0x55
do {
sum+=buffer[ctr++];
} while (ctr<number);
sum &= 0xff; //low 8 bits only
sum ^= 0xFF; //inverted
return sum;
/*------------------------------------------------- ultrasonicCmd -----
| Function sendCommand
| Purpose: Issues a burst-and-listen or listenonly
command based on the number of objects to be detected.
| Parameters:
| cmd (IN) -- determines which preset command is run
| • 0 = Preset 1 Burst + Listen command
| • 1 = Preset 2 Burst + Listen command
| • 2 = Preset 1 Listen Only command
| • 3 = Preset 2 Listen Only command
| number (IN) -- PGA460 can capture time-offlight,
width, and amplitude for 1 to 8 objects.
| TCI is limited to time-of-flight measurement data only.
| Returns: none
void sendCommand(int cmd, int number)
//send a command packet to the device
int ctr;
byte bufCmd[4]; // prepare bufCmd
bufCmd[0]=syncByte;
bufCmd[2]=number;
numObj=number; //update number of objects to detect
memset(objTime, 0xFF, 8); // reset buffer
switch (cmd)
case 0: // Send Preset 1 Burst + Listen command
bufCmd[1] = P1BL;
bufCmd[3] = Checksum(bufCmd,3);
case 1: // Send Preset 2 Burst + Listen command
bufCmd[1] = P2BL;
case 3: // Send Preset 1 Listen Only command
bufCmd[1] = P1LO;
case 4: // Send Preset 2 Listen Only command
bufCmd[1] = P2LO;
default: return;
//Now write buffer
for (ctr=0;ctr<4;ctr++)
spi_xfer(PGA,bufCmd[ctr],8);
void pullResult(void)
//Now data sheet disagrees with itself on whether a checksum is required for
//the read command. Code shows it, but data sheet says it is not needed.
//Including anyway....
byte buf[3]; //temporary TX buffer
int ctr;
buf[0]=syncByte;
buf[1]=UMR;
buf[2]=checksum(buf,2);
//Now write buffer
for (ctr=0;ctr<3;ctr++)
spi_xfer(PGA,buf[ctr],8);
//clear incoming buffer
memset(ultraMeasResult,0,sizeof(ultraMeasResult));
//Now need to read reply
delay_us(125); //worst case command processing dead time
for(ctr=0; ctr<((2+(numObj*4))); ctr++)
//read max 'numObj replies
ultraMeasResult[ctr]=spi_xfer(PGA,0xFF,8);
float convertResult(byte source)
int16 speedSound = 343;
int index;
int16 objDist;
index=(source/3)*3;
switch(source%3)
case 0: //Objn Distance (m)
objDist = make16(ultraMeasResult[index+1],ultraMeasResult[index+2]);
return (objDist/2*0.000001)*speedSound;
case 1: //Objn Width (us)
return (ultraMeasResult[index+3])*16.0;
case 2: //Objn Peak Amplitude
return ultraMeasResult[index+4];
//Now, comms requires 300uSec active data before starting
//Clock out 0xFF's to generate this
int ctr;
float distance;
for (ctr=0;ctr<8;ctr++)
spi_xfer(PGA,0x55,8);
//Now need to issue a preset 1 command, then pause for 100uSec
//and read response
while (TRUE)
sendCommand(P1BL, 1); //one channel only
delay_ms(70); //worst case command delay is 65mSec
pullResult();
//Now need to convert these values
for (ctr=0; ctr<numObj; ctr++)
distance=convertResult(0+(ctr*3));
printf("Distance %f/n", distance);
delay_ms(500); //slow things down
Uses a com port for output (move this somewhere to suit your hardware. |
L.T.
Posted: Thu Aug 13, 2020 3:14 am |
Thanks, I'll try it now.
I tried but PGA didn't answer. |
L.T.
Posted: Fri Aug 14, 2020 12:45 am |
Hey there,
I found a problem in the code. memset function doesnt work perfectly. It isn't erasing all data in misoBuf array. misoBuf is the array of slave device's answers.
memset's description in 16F18346.h file is:
Code: | _bif void memset(unsigned int8* destination, unsigned int8 value, unsigned int16 num); |
And I used memset function in this part for clean the buffer:
Code: | void pga460_spiTransfer(BYTE* mosi, BYTE size )
uint16 temp2;
memset(misoBuf[0], 0x00, sizeof(misoBuf)); // idle-low receive buffer data
for (int i = 0; i<size; i++)
//digitalWrite(SPI_CS, LOW);
misoBuf[i] = usscSPI_transfer(mosi[i]);
//digitalWrite(SPI_CS, HIGH);
return;
When I used memset as you can see in the code above, I get misoBuf array as follows:
misoBuf before memset:
Code: | "\x e9\x ea\x eb\x ec\x ed\x ee\x ef\x 0\x 88\x 88\x 88\x 88\x 88\x 88\x 0\x 20\x 21\x ff\x 84\x 21\x 8\x 42\x 0\x 0\x 0\x 75\x 1b\x 81\x 20\x 0\x 0\x 5\x e9\x 0\x 1\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x a0\x 1\x 90\x a6\x 8\x f0\x f1\x f2\x f3\x f4\x f5\x f6\x f7\x f8\x f9\x fa\x fb\x fc\x fd\x fe\x ff\x 0\x 1\x 2\x 3\x 4\x 5\x 6\x 7\x 8\x 9\x a\x b\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0" |
misoBuf after memset:
Code: | "\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 88\x 88\x 88\x 88\x 88\x 88\x 0\x e9\x 20\x ff\x 84\x 21\x 8\x 42\x 0\x 0\x 0\x 75\x 1b\x 6b\x 21\x 0\x 0\x 5\x 20\x 0\x 1\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x a0\x 1\x 90\x a6\x 8\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0" |
I tried a lot of version of using memset as below:
memset(&misoBuf[0], 0x00, sizeof(misoBuf));
memset(*misoBuf[0], 0x00, sizeof(misoBuf));
*memset(misoBuf[0], 0x00, sizeof(misoBuf));
*memset(&misoBuf[0], 0x00, sizeof(misoBuf));
etc.
Even, I wrote memset function myself. You can see below.
Code: | void *tmemset8( uint8 * adrest, uint8 datat, uint8 sizet){
while(sizet-->0){
*adrest=data;
adrest++;}
tmemset8(misoBuf, 0x00, sizeof(misoBuf)); // idle-low receive buffer data
return;
And I get same result. It never erase all data. I tried a lot of version of writing new memset function as below:
for(int index=0;index<sizet;index++)
adrest[index] = datat;
return(adrest);
Code: | void tmemset8( uint8 * adrest, uint8 datat, uint8 sizet){
return(adrest);
etc.
What is the problem guys? |
Posted: Fri Aug 14, 2020 1:54 am |
This is not how you pass the address of an array in C.
You are giving memset the value of the 1st element in the array.
Quote: | void pga460_spiTransfer(BYTE* mosi, BYTE size )
uint16 temp2;
Posted: Fri Aug 14, 2020 2:00 am |
So you are actually erasing loads of stuff in the wrong part of the
processor's memory. The code I posted use the correct syntax for memset. |
L.T.
Posted: Fri Aug 14, 2020 2:50 am |
PCM programmer wrote: | This is not how you pass the address of an array in C.
uint16 temp2;
When I did like you told, I get the result as follows:
Code: | "\x e9\x ea\x eb\x ec\x ed\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x f6\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 75\x 1f\x 3\x 1\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x a0\x 1\x 90\x a6\x 8\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0" |
L.T.
Posted: Fri Aug 14, 2020 2:55 am |
Ttelmah wrote: | So you are actually erasing loads of stuff in the wrong part of the
I can't see any difference between yours and mine. I used memset for objTime or ultraMeasResult. It does not work for them too, some of them are reset and some remain stable. |
Posted: Fri Aug 14, 2020 3:39 am |
Do you think I am telling you to do this ?
Quote: | memset(misoBuf[0], 0x00, sizeof(misoBuf)); // idle-low receive buffer data |
I am not telling you to do that. I was quoting your code.
This is what you should do:
Code: | memset(misoBuf, 0x00, sizeof(misoBuf)); |
If it doesn't work, then post your compiler version. |
L.T.
Posted: Fri Aug 14, 2020 4:50 am |
PCM programmer wrote: | Do you think I am telling you to do this ?
I tried it too.. Doesnt work. MPLABX IDE V5.05 and CCS C Compiler v5.076 |
Posted: Fri Aug 14, 2020 5:06 am |
See the test program posted below.
Here are the results. First it prints the array contents to show that
it holds all these numbers.
Quote: |
0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,
16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,
32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,
48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,
64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,
80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,
96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,
112,113,114,115,116,117,118,119,120,121,122,123,124,125,126,127,
128,129,130,
Then it prints the array again, after running memset on it. It works.
This was tested with vs. 5.094. If it doesn't work with your version,
then I'll install your version and test it.
Quote: |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,
Test program:
Code: | #include <18F46K22.h>
#fuses NOWDT
#use delay (internal=4M)
BYTE misoBuf[131] =
0, 1, 2, 3, 4, 5, 6, 7, 8, 9,10,11,12,13,14,15,
109,110,111,112,113,114,115,116,117,118,119,120,
121,122,123,124,125,126,127,128,129,130
int8 i;
for(i=0; i<sizeof(misoBuf); i++)
if(i%16 == 0)
putc('\r');
printf("%u,", misoBuf[i]);
putc('\r');
putc('\r');
if(i%16 == 0)
putc('\r');
while(TRUE);
L.T.
Posted: Fri Aug 14, 2020 6:08 am |
I cant run the program, it gave an error about RS232.Then I erased RS232 part, because it is not necessary. I did debug, but when it came memset line, program has closed. |
Joined: 01 Jul 2010 Posts: 7897 Location: Greensville,Ontario
Posted: Fri Aug 14, 2020 6:24 am |
what was the RS232 error ?? |
L.T.
Posted: Fri Aug 14, 2020 6:51 am |
temtronic wrote: | what was the RS232 error ?? |
I had to choose a pin (#select_pin), but I have no idea which pin is correct to read from the computer. |
Posted: Mon Aug 17, 2020 3:01 am |
Working with Ttelmah, I was able to get MPLAB X vs. 5.30 to display printf
statements in the UART1 tab of the MPLAB X Simulator.
I installed CCS vs. 5.076 (same as your version). I compiled the
test program shown below and it worked fine. It displayed this output.
This shows that memset() did zero the array correctly.
Code: | 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,
128,129,130,
0,0,0,
Test program:
#fuses NOWDT
#pin_select U1TX = PIN_C6
#pin_select U1RX = PIN_C7
BYTE misoBuf[131] =
int8 i;
if(i%16 == 0)
printf("\r\n");
printf("\r\n");
printf("\r\n");
if(i%16 == 0)
printf("\r\n");
while(TRUE);
