A Driver for the XPT2046 or TI TSC2046 Touch Controllers
cbarberis
PostPosted: Mon Aug 10, 2020 3:47 pm     Reply with quote
This is a functional driver you can use on the XPT2046 or the TI TSC2046, it may also work with the ADS7843 but I cannot attest to that particular device.
My testing was done on a cheap ILI9341 (240 X 320) TFT display that has this touch screen the module is excellent and only costs $10 from Amazon. I did not include here the driver and libraries for the TFT display this is just for the touch controller and you can easily test it via the serial port.
//  Interfacing dsPIC33FJ128GP802 microcontroller touch display using the XPT2046
//  Touch Controller which is the same as TSC2046 from TI,This quick test does not
//  include the ILI9341 TFT LCD display just a basic functionality test using the
//  serial port to report X,Y and Z touch values
//  Carlos Barberis
//  August 10, 2020
#include <33FJ128GP802.h>
#device ADC=12
#device ICSP=1
//#device ICD=TRUE
#FUSES NOWDT                      //No Watch Dog Timer
//#FUSES WDT //be careful using WDT make sure is timed correctly otherwise it will never work
#FUSES WPRES32                  //Watch Dog Timer PreScalar 1:32
#FUSES WPOSTS10                 //Watch Dog Timer PostScalar 1:512
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NODEBUG
//#FUSES DEBUG
#use delay(internal = 64MHz)
//////////////////////// Connector Wiring for Touch Module //////////////////////////
// TOUCH-MISO -->   PIN_B4
// TOUCH-IRQ  -->   PIN_B7
// TOUCH-SCK  -->   PIN_B6
// TOUCH-MOSI -->   PIN_B5
// TOUCH-CS   -->   PIN_B8
// define XPT2046 Touch module pin connections for this particular setup
#define TOUCH_CS    PIN_B8   // chip select pin
#define TOUCH_IRQ   PIN_B7   // Interrupt request
#pin_select SDI2=PIN_B4
#pin_select SDO2=PIN_B5
#pin_select SCK2OUT=PIN_B6
#pin_select U1TX=PIN_B14
#pin_select U1RX=PIN_B15
#use spi(MASTER, SPI2, MODE=0, BITS=8, baud=2000000,stream = TOUCH)
#use rs232(UART1, baud=9600,restart_wdt, errors,stream= USART1) // connected to USB serial
 /// Function Prototypes ///////
 void ext0_isr(void);
 void ReadTouch_XYZData(void);
 void ReadTouch_XData(void);
 void ReadTouch_YData(void);
 unsigned int X_Val,Y_Val;
 unsigned int Z_Val,Z1,Z2;
 unsigned int xraw,yraw;
 unsigned int ScreenRotation = 1; //screen rotation
 int1 TOUCH_FLAG = 0;
 #define X_COMMAND_BYTE  0xD0  // get X values
 #define Y_COMMAND_BYTE  0x90  // get Y values
 #define Z1_COMMAND_BYTE 0xB1 // get Z1 value
 #define Z2_COMMAND_BYTE 0xC1 // get Z2 value
 #define MSB_BIT_MASK    0x7F // Bit mask for MSB byte
 #define Z_THRESHOLD     400
#int_ext0
void ext0_isr() {
   TOUCH_FLAG = 1;
void ReadTouch_XData()  {     // read 12 bit data from SPI bus after sending a command byte
  unsigned int8 MSB =0,LSB =0;
   output_low(PIN_B8);
   delay_us(2);
   SPI_XFER(TOUCH,X_COMMAND_BYTE); // send command byte twice to dump first reading
   MSB = SPI_XFER(TOUCH,0);
   LSB = SPI_XFER(TOUCH,0);
   output_high(PIN_B8);
   xraw = (((MSB & MSB_BIT_MASK) << 8)+ LSB) >> 3;
void ReadTouch_YData()  {     // read 12 bit data from SPI bus after sending a command byte
   output_low(PIN_B8);
   delay_us(2);
   SPI_XFER(TOUCH,Y_COMMAND_BYTE); // send command byte
   yraw = (((MSB & MSB_BIT_MASK) << 8)+ LSB) >> 3;
void ReadTouch_XYZData()  {  // read 12 bit data from SPI bus after sending a command byte for X,Y,Z1&Z2 measurements
   output_low(PIN_B8);
   delay_us(2);
   /////////////////////Gather Z pressure readings////////////////////////////////////
   SPI_XFER(TOUCH,Z1_COMMAND_BYTE); // send command byte
   Z1 = (((MSB & MSB_BIT_MASK) << 8)+ LSB) >> 3;
   SPI_XFER(TOUCH,Z2_COMMAND_BYTE); // send command byte
   Z2 = (((MSB & MSB_BIT_MASK) << 8)+ LSB) >> 3;
   Z_Val =  Z1 + 4095;
   Z_Val -= Z2;
   if(Z_Val >= Z_THRESHOLD) {  // if we have more than the pressure threshold then read X&Y data
   LSB = SPI_XFER(TOUCH,0);;
      output_high(PIN_B8); // in case Z_Val did not qualify lets bring CS high
      switch (ScreenRotation) {     /// We need to know the display rotation to compensate for X,Y locations
      case 1:
      X_Val = 4095 - yraw;
      Y_Val = 4095 - xraw;
      case 2:
      X_Val = xraw;
      Y_Val = yraw;
      case 3:
      X_Val = yraw;
      default: // 4
      X_Val = 4095 - xraw;
      Y_Val = 4095 - yraw;
/////////////////////////////////// TEST  PROGRAM  /////////////////////////////////////////////////
 set_tris_b (0x9090);
 set_pullup(true, PIN_B7);
 enable_interrupts(INT_EXT0);
 ext_int_edge( H_TO_L );
 ReadTouch_XData(); // just to init once may not be really needed
while(1) {
 if(TOUCH_FLAG)
   while(!input(PIN_B7))  {
   ReadTouch_XYZData();
   printf("XposRaw value = %lu , ",xraw);
   printf("YposRaw value = %lu , ",yraw);
   printf("Xpos value = %lu , ",X_Val);
   printf("Ypos value = %lu , ",Y_Val);
   printf("Z value = %lu \r\n",Z_Val);
   TOUCH_FLAG = 0;}
//////////////////////////////////////////  END OF FILE   ///////////////////////////////////////////////////
Enjoy!!!
