Pichuqy_1
| Migration between PIC18F4550 and PIC24FJ64GA006 |
Posted: Sat Oct 19, 2019 6:41 pm |
Hello everyone.
I have a program made in PIC18F4550 and I need to pass it to PIC24f.
From what I could learn, migration is not direct and I need to change many things. I was able to solve many, but not all.
I would like to ask some questions:
Does the data type change? I have errors of this type:
Can I use the same graphic library? Apparently, they are just data type errors, but I can't remove them.
HDM64GS12.c
The same problem for the keyboard library.
kbd_lib.c
The library for writing / reading the internal EEprom (internal_eeprom.c) is not compatible with this microcontroller model, right?
Thank you very much for your help. |
Posted: Sat Oct 19, 2019 10:49 pm |
Try actually looking at your post.
All the included bits are not visible. Doesn't help us to see what you are
asking.....
General comments:
The PIC24 you list does _not_ have internal EEPROM. So 'of course'
the internal EEPROM functions won't work. Choices are:
1) Use an external EEPROM or
2) Use the 'virtual eeprom' driver.
The latter simulates EEPROM behaviour using a couple of pages of
the flash program memory.
Now data types. This is where being explicit helps. If your code uses
explicit types it'll convert directly. Load stdint.h, and use uint8_t etc.,
and the types will work on both families. However it you have been
making assumptions and using default types like 'int', everything
changes. On the PIC24, the default 'int' is 16bit, and everything
defaults to signed instead of the unsigned default on the PIC16/18. |
Joined: 01 Jul 2010 Posts: 9608 Location: Greensville,Ontario
Posted: Sun Oct 20, 2019 7:30 am |
I have to wonder WHY the
.000030517578125 number is in the code ?
It's highly unlikely the PIC can accurately use it.
Then I 'd like to know why the migration to a PIC24 device. I'm thinking maybe speed ? though scaled integers beat floats everyday of the week.
just curious
Posted: Sun Oct 20, 2019 8:52 am |
My comment about looking at the post no longer applies. The files are
now visible. I think the sharing site you have used took a while to actually
make them available so when I looked at first the files were not showing...
You don't show the processor setup and include.
Now, the processor include file defines the byte and int1 types. So many
of your errors will disappear once this is loaded correctly.
sprintf is defined in string.h. Suggests this is also not being loaded.
So most of your problems are just in the setup you are using to load the
files.
There are a couple 'left' though. First is CCP. The PIC24 does not have
a CCP peripheral. On the PIC24, this is done by two separate peripherals.
The input capture unit, and the output compare unit. You need to use
whichever you need and change the setups to match.
The EXT interrupt, is EXT1, EXT2 etc., on the PIC24.
Peripheral setups will always be different. You need to look at what the
options are for the PIC24 timer. It has far more options than the PIC18
one, but with that comes changes in the values needed to configure it. |
Pichuqy_1
Posted: Sun Oct 20, 2019 7:18 pm |
Hello everyone. Thanks for your comments.
Ttelmah:
The reason I changed my microcontroller is because I ran out of program memory, and the only PIC I have available with more memory is the 24FJ64GA006.
The number .000030517578125, comes by default in the library MATH.h. My intention was to show the errors in the definition of variables (float32), which I believe are due to the type of data.
temtronic:
I really didn't know that this microcontroller hadn't internal eeprom. I was very surprised. I already removed it from the main code and I will add an external memory.
What isn't clear to me, is how to configure the interruption by change of state on pin RB0. Does the nomenclature starts from EXT1 in PIC24?
This is the main file:
#include "24FJ64GA006.h" //pic a utilizar
#FUSES NOJTAG //JTAG disabled
#FUSES ICSP2 //ICD uses PGC2/PGD2 pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
//#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is clock output
#FUSES PR //Pimary oscillaotr disabled
#use delay(clock=20000000)
#use STANDARD_IO(B)
#use STANDARD_IO(C)
#use STANDARD_IO(D)
#use STANDARD_IO(E)
#use STANDARD_IO(F)
#use STANDARD_IO(G)
#BYTE INTCON3 = 0xFF0
#BYTE PIR1 = 0xF9E //Peripheral interruption signaling control register
#include "MATH.h"
#include "stdlib.h"
#include "HDM64GS12.h"
#include "GRAPHICS.h"
#include "flex_kbd_4x4.h"
#include "DS3231_libreria_2.h"
#include "clabe_acceso_lcd_grafico.h"
#include "ds3231_configuracion_lcd_grafico.h"
#include "dia_semana.h"
#include "conf_timer.h"
//#include "internal_eeprom.h"
#include "TMR.h"
char valor_lm35[10];
long medicion,datox,dato;
int reset=0x00;
int cambio=0,automatico=0x00;
int control_teclado=0x00; //It is used so that the menu cannot be selected again.
int bandera_backlight=0;
static int last=0;
int current;
int int_rb_1=0;
int bandera_conf=0;
char logo_1[]="SUNDAY";
char logo_2[]="MONDAY";
#int_EXT
ext_isr(void) {
if(cambio==0){
cambio=1;
output_low(PIN_B13);
ext_int_edge(H_TO_L);
else{
cambio=0;
ext_int_edge(L_TO_H);
output_high(PIN_B13);
//suma_segundos ++;
borra=1;
#int_EXT1
ext_isr1(void)
if(bandera_conf==1){
//bandera_conf=0;
if((seleccion_menu_1 >= 3)){
seleccion_menu_1=0;
seleccion_menu_1 = seleccion_menu_1 + 1;
delay_ms(250);
else{
if((seleccion_menu >= 7)){
seleccion_menu=0;
seleccion_menu = seleccion_menu + 1;
CONF_DIA_SEMANA();
#int_EXT2
ext_isr2(void)
if(bandera_conf==1){ //El pirmer IF se utiliza para configurar el menu de los TIMER
//El else se utiliza para configurar el menu de los DIAS
if((seleccion_menu_1 <= 0)){ //Tope maximo para elegir la cantidas de minutos de activación 15 min a 3 horas
seleccion_menu_1=3;
seleccion_menu_1 = seleccion_menu_1 - 1;
delay_ms(250);
else{
if((seleccion_menu <= 0)){
seleccion_menu=8;
seleccion_menu = seleccion_menu - 1;
CONF_DIA_SEMANA();
///PROGRAMA
// setup_ccp1(CCP_CAPTURE_RE);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8); //La frecuencia a la que el timer realiza un paso: 20000000/4/8= 0.0000016;
// disable_interrupts(INT_CCP1);
disable_interrupts(INT_EXT);
disable_interrupts(INT_EXT1);
disable_interrupts(INT_EXT2);
ext_int_edge(L_TO_H); //Configuracion INT_EXT de nivel alto a bajo RB0
ext_int_edge(1,L_TO_H); //Configuración INT_EXT1 de nivel alto a bajo RB1
ext_int_edge(2,L_TO_H); //Configuración INT_EXT2 de nivel alto a bajo RB2
// setup_adc_ports (AN0|VSS_VDD);
// setup_adc(ADC_CLOCK_DIV_2); //enciende adc
// set_adc_channel(0); //elige canal a medir RA0
glcd_init(ON);
//#rom int8 0xF00004={'1','2','3','4'}; //ver http://www.ccsinfo.com/forum/viewtopic.php?p=42027
//#rom int8 0xF00008={0x00}; //ver http://www.forosdeelectronica.com/f24/programador-pic-18f2550-poder-montar-despues-pickit2-clone-40738/
reset=read_eeprom(0x08);
//if(reset==0x00){ //CLABE DE ACCESO, no ingresa al programa hasta que no sea correcta.
//El if se realiza para que solo ingrese a la clabe cuando el equipo se agapa.
//INICIO_CLABE_ACCESO(); //Si el equipo se resetea utilizando la letra "D", no se ingresa a la CLABE
//write_eeprom(0x08,0x00);
//delay_ms(1000); // wait a second
OSC_Start();
Disable_32kHZ();
IntSqw_Set(OUT_1Hz); // enable SQW output with frequency of 1Hz
//RTC_Set(mytime); // write time and date to the RTC chip
glcd_fillScreen(OFF); //Borramos LCD
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
CONF_DIA_SEMANA();
do{
if(borra==1){ //En este if se entra cuando se termina de realizar la interrupción por RB0
mytime=RTC_Get(); // read current time and date from the RTC chip
//Se actualiza lectura de reloj
delay_ms(100); // wait 100 ms
glcd_rect(0,0,70,6,1,OFF); //Borramos minutos horas segundos
sprintf(valor_hora,"%02u:%02u:%02u",mytime->hours,mytime->minutes,mytime->seconds); //imprime la variable
glcd_text57(0,0,valor_hora,1,1);
sprintf(valor_hora,"%02u/%02u/20%02u",mytime->day ,mytime->month,mytime->year); //imprime la variable
glcd_text57(60,0,valor_hora,1,1);
//chip_temp = Get_Temperature(); // read chip temperature
//rtc_print(); // print all data
borra=0; //Variable para controlar el fin de la interrupcion. Cuando Se termina de ejecutar todo, se pone //la variable de control en 0, asi solo se va a ingresar cuando la interrupcion por RB0 llege
//a su fin, osea que pasó un segundo.
//glcd_text57(0,54,D,1,1);
k=kbd_getc();
switch (k){
case 'D':
CONFIGURACION();
//Se configura la hora del reloj de tiempo real.
case 'C':
bandera_conf =1;
CONFIGURACION_ENCENDIDO_APAGADO();
//Se configura cada día con su TIMMER.
}while(TRUE);
I managed to reduce errors to this:
Posted: Sun Oct 20, 2019 8:08 pm |
| Pichuqy_1 wrote: |
Setup_timer_1
INT_EXT
INT_EXT
You have minor spelling or syntax errors. If you looked in the .h file for
your PIC, you would see the answers immediately. |
Posted: Mon Oct 21, 2019 12:08 am |
Setup_timer_1 -> setup_timer1
INT_EXT -> INT_EXT0
Beware (of course), that the frequency fed to a timer, is FOSC/2 on
a PIC24, against FOSC/4 on a PIC18. Anything timer based will need to
have timings adjusted.
Comment on this line is wrong. Actually the primary oscillator is enabled.
It needs to be....
Wrong. This chip does not have an INTCON3 register. The address you are
using will be into the standard RAM. |
Pichuqy_1
Posted: Mon Oct 21, 2019 4:39 pm |
Thank you for your answers.
I am finishing with the compilation and now, I have problems with the functions. With the PIC18F4550 the program was compiled perfectly, but not now.
I still don't understand the reason why the conflict with the functions.
Is the definition of functions different for PIC24?
Where can I learn how to solve this problem?
I know that my programming is not the best, but I am trying to improve it.
This is the main.c where I call the two functions.
This is one of the functions.
This is the other
Posted: Mon Oct 21, 2019 4:47 pm |
One thing to watch out for: the 8 bit compilers (PCB, PCM and PCH) all treat integers as *unsigned* by default. The 16 bit compiler treats integers as *signed* by default.
When I migrated a working project from a PIC18 to a dsPIC I learned this little tidbit the hard way. It's also, coincidentally, the reason why I now *always* explicitly declare whether a variable is signed or unsigned no matter what. |
Posted: Mon Oct 21, 2019 7:59 pm |
Why are you highlighting "CONFIGURACION_ENCENDIDO_APAGADO()" ?
It's not listed as an error.
The only function listed as an error is "CONFIGURACION()". You are
getting the "Function used but not defined" error.
This error occurs if you have a function prototype for CONFIGURACION()
but you don't have the actual function declaration anywhere in your
program. It might be in a file, but you forgot to #include the file. |
Pichuqy_1
Posted: Mon Oct 21, 2019 10:01 pm |
I can't figure out what is going on with this.
I have not forgotten to add the .h files. The next photo shows it.
| PCM programmer wrote: |
"Why are you highlighting "CONFIGURACION_ENCENDIDO_APAGADO()" ?
It's not listed as an error." |
For both functions it shows me the same error, but I don't understand why it only shows me one at a time.
There is something I can't understand with the definition of functions. Notice how the error translates when I comment on the function // CONFIGURATION () ;.
[/img]
I really don't know what to do now. I think I'm going to have to look for a PIC18 with more program memory. |
Posted: Tue Oct 22, 2019 1:31 am |
The problem is almost certainly 'types'. On the PIC18, byte, int, char are
all accepted as the same type. On the PIC18, they differ. int, is a signed int16,
char is a signed int8, byte is an unsigned int8. Now it is saying the function
is not defined, because it cannot find a function definition, with the variables
required that matches how it is actually being called. I had this when using
some functions that used byte, and the actual call was using char. |
Posted: Tue Oct 22, 2019 12:02 pm |
Also we see something not good. In the bottom left corner of the first
image, we see:
| Quote: | | Compiler Toolchain: CCSC vs. 5.009 |
Red flag. |
Pichuqy_1
Posted: Tue Oct 22, 2019 4:16 pm |
| Sorry, but I don't understand. Is there something wrong with the compiler version? |
Posted: Tue Oct 22, 2019 4:49 pm |
Yes, "inside information" for those of us who have used the compiler for many years. Version 5 was initially very unreliable and riddled with bugs. Somewhere after your version (not sure exactly) was when version 5 approached being usable. As for myself, at the time version 5 became available, I stuck with version 4.099 for as long as I possibly could, then started to use version 4.141 because it supported a dsPIC I was using that 4.099 didn't.
I do remember watching the "chatter" here regarding version 5 and thinking "I'm not upgrading yet." |
