lgeorge123
| PIC18F452 UART |
Posted: Wed May 15, 2019 5:52 am |
In the follow codes, ascii value 1.23 is send to pic18f452 via uart. How to modify the code in order to make some judgement in ascii value ?
| Code: | #include <18f452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG
#use RS232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, ERRORS)
int8 j;
void main(){
// Set internal oscillator to 8MHz
while(TRUE){
if(kbhit()){ // If a character available
j = getc(); // UART read
putc(j); // Send it back
like if (j=='1.23'), this show error !! |
dluu13
Posted: Wed May 15, 2019 6:07 am |
Look up the atoi(), atof(), and atol() functions in the manual. They turn null terminated strings into numbers that will allow you to do what you want.
They are not specific to ccs, so you can just Google them as well. |
