Relay controller - 8 ports with led status
Post new topic   Reply to topic    CCS Forum Index -> Code Library
MassaM
PostPosted: Fri Jun 21, 2019 9:28 am     Reply with quote
// ************************************************ Array version ************************************************ //
   Project:    Demo Controller Board - 8 Channels Relay with status LEDs and push buttons for an ON/OFF toggle
   Compiler:   CCS-C-PIC - PCWHD Version 5.076
   Author:     MassaM, June 2019
   Chip:       PIC16F877A@20Mhz
   Copyright:  No copy-rights nor copy-wrongs! :)
   Request:    Make it better and post it back on this thread, so we all learn please! And always give credits where due, as what goes around, comes around! ;)
   Forum Link: http://www.ccsinfo.com/forum/viewtopic.php?t=58066
   Credits:    Ttelmah -> http://www.ccsinfo.com/forum/profile.php?mode=viewprofile&u=14537&sid=42ae004153892ee2adcd40879d100ea4
               temtronic -> http://www.ccsinfo.com/forum/profile.php?mode=viewprofile&u=15187
               dluu13 -> http://www.ccsinfo.com/forum/profile.php?mode=viewprofile&u=24556&sid=42ae004153892ee2adcd40879d100ea4
               PCM programmer -> http://www.ccsinfo.com/forum/profile.php?mode=viewprofile&u=4
#include <16F877A.h>
//Note: Edited 1 & 2 on 17th July 2019
#fuses HS, BROWNOUT, PUT, NOWDT // Edited 1: HS instead of XT
#use delay(crystal=16M)  // Edited 2: was (clock=20M)
#use rs232(stream=SERIAL, baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)  // settings for Serial/Terminal outputs
#define FOSC getenv("CLOCK")  // Get PIC oscillator frequency
#define TIMER0_PRELOAD (256 - (FOSC/4/256/100))
// Array version variables
int16 switches[] = {PIN_B0,PIN_B1,PIN_B2,PIN_B3,PIN_B4,PIN_B5,PIN_B6,PIN_B7};
int16 leds[] = {PIN_D0,PIN_D1,PIN_D2,PIN_D3,PIN_D4,PIN_D5,PIN_D6,PIN_D7};
int8 switch_is_down[] = {FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE};
int8 active_state[] = {0,0,0,0,0,0,0,0};
int8 previous_state[] = {0,0,0,0,0,0,0,0};
int8 portb_states;
// Array version functions
void display_binary(char c) // Used for printing binary out to terminal as debugging (Credit to: PCM Programmer)
   char i;
   putc('0');
   putc('b');
   for(i = 0; i < 8; i++)
       if(c & 0x80)
          putc('1');
          putc('0');
       c <<= 1;
void clearSwitches_Array()
   int8 i;
   for(i=0; i < 8; i++)
      switch_is_down[i] = FALSE;  // Clear the switch is pushed flag
void pollSwitches_Array()
   int8 i;
      if(switch_is_down[i] == TRUE)
         output_toggle(leds[i]);
void checkStates_Array()
   int8 i;
      active_state[i] = input(switches[i]);  // Read the button
      if((previous_state[i] == 1) && (active_state[i] == 0))
         switch_is_down[i] = TRUE;
      previous_state[i] = active_state[i];  // Save current value for next time
      pollSwitches_Array();                 // <- Moved this function call from the main's while(TRUE) to here and THE Compiler is HAPPY NOW! :)
                                            // Credit: dluu13 -> For the awesome clue! Thanks! :)
void timer0_init(void)
   setup_timer_0(T0_INTERNAL | T0_DIV_256 | T0_8_BIT);
   set_timer0(TIMER0_PRELOAD);
   clear_interrupt(INT_TIMER0);
#int_timer0
void timer0_isr(void)
   set_rtcc(TIMER0_PRELOAD);  // Reload Timer0 for 10ms rate
   checkStates_Array();       // All working now! :)
void initAll(){
   timer0_init();
   clearSwitches_Array();
   portb_states = input_b();                 // read the state of all switches as full port
   // Uncomment the block below for port B states debug to terminal output
   printf("Initial PORT B States\r\n");      // print the initial port state
   display_binary(portb_states);             // print the port state to terminal in binary
   printf("\r\n---------------------\r\n");  // print separation lines
   initAll();
      printf("Updated PORT B States\r\n");      // print the updated port state
   } // while true
} // main
Youtube links for:
Simulation:
https://www.youtube.com/watch?v=gqhuIhm1n2k
Demonstration on breadboard:
https://www.youtube.com/watch?v=R96LOQxJpZk
Hope this helps.
Cheers!
while(!dead)
keepLearning();
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
