40inD
Joined: 30 Jul 2007 Posts: 112 Location: Moscow, Russia
18F2550 C4 C5 problem |
Posted: Thu Mar 14, 2019 2:50 pm |
When I try to toggle defined pins TRI1, TRI2 as C4 and C5 then nothing happens.
But if i define those pins for example as A1 and A2 then it works.
I can't understand, why C4 and C5 does not work?
#include <18F2550.h>
#device ADC=8
#include <stdlib.h>
#fuses INTRC
#FUSES WDT2048
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES PUT
#use delay(internal=8000000,RESTART_WDT)
#define TRI1 PIN_C4
#define TRI2 PIN_C5
setup_oscillator(OSC_8MHz);
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_64|ADC_TAD_MUL_20);
set_adc_channel(0);
//setup_WDT( WDT_2S);
{ output_high(TRI1);
output_high(TRI2);
output_low(TRI1);
output_low(TRI2);
}// while true
Joined: 01 Jul 2010 Posts: 9108 Location: Greensville,Ontario
Posted: Thu Mar 14, 2019 2:55 pm |
Well it's time to download the 438 page datasheet and read page 15 !
Table 1-2 will tell you why.....
If I say why, you won't remember for next time. Prof told me that back in '74.
40inD
Posted: Thu Mar 14, 2019 3:04 pm |
Thanks, I always forget about input-only pins. |
Posted: Thu Mar 14, 2019 3:49 pm |
Ever since PICs grew more than 18 pins, you've needed to read the datasheet. It's amazing what they can jam into the epoxy these days !
Posted: Fri Mar 15, 2019 4:06 am |
Actually I think you needed to read the sheet even when they were 18pin.
After all in those days you were having to learn about TRIS and which
pins took the power etc..
However it was a lot easier when the sheet was only about thirty pages
in total.... |
Posted: Fri Mar 15, 2019 5:12 am |
re:
in total....
I'd do that while the PIC was being erased in the UV chamber.......
