in_nursery
MRF89XA |
Posted: Tue Feb 05, 2019 11:08 am |
Hi all
I make research on the forum with no luck. I'm stuck with a MRF89XA.
basic driver
MRF89XA.c
#include <MRF89XA.h>
// First time configuration settings for MRF89XA
unsigned int8 InitConfigRegs[] = {
/* 0 */ CHIPMODE_STBYMODE | FREQBAND_915 | VCO_TRIM_11,
/* 1 */ MODSEL_FSK | DATAMODE_PACKET | IFGAIN_0,
/* 2 */ FREGDEV_80,
/* 3 */ BITRATE_25,
/* 4 */ OOKFLOORTHRESH_VALUE,
/* 5 */ FIFOSIZE_64 | FIFO_THRSHOLD_1,
/* 6 */ 0,
/* 7 */ 0,
/* 8 */ 0,
/* 9 */ 0,
/* 10 */ 0,
/* 11 */ 0,
/* 12 */ DEF_PARAMP | PA_RAMP_23,
/* 13 */ IRQ0_RX_STDBY_SYNCADRS | IRQ1_RX_STDBY_CRCOK | IRQ1_TX_TXDONE,
/* 14 */ DEF_IRQPARAM1 | IRQ0_TX_START_FIFOTHRESH | IRQ1_PLL_LOCK_PIN_ON,
/* 15 */ RSSIIRQTHRESH_VALUE,
/* 16 */ PASSIVEFILT_378 | RXFC_FOPLUS100,
/* 17 */ DEF_RXPARAM1 | FO_100,
/* 18 */ DEF_RXPARAM2 | POLYPFILT_OFF | SYNC_SIZE_32 | SYNC_ON | SYNC_ERRORS_0,
/* 19 */ DEF_RXPARAM3,
/* 20 */ 0,
/* 21 */ OOK_THRESH_DECSTEP_000 | OOK_THRESH_DECPERIOD_000 | OOK_THRESH_AVERAGING_00,
/* 22 */ 0x69, // 1st byte of Sync word,
/* 23 */ 0x81, // 2nd byte of Sync word,
/* 24 */ 0x7E, // 3rd byte of Sync word,
/* 25 */ 0x96, // 4th byte of Sync word,
/* 26 */ FC_400 | TXPOWER_13,
/* 27 */ CLKOUT_ON | CLKOUT_12800,
/* 28 */ MANCHESTER_OFF | 64,
/* 29 */ NODEADRS_VALUE,
/* 30 */ PKT_FORMAT_VARIABLE | PREAMBLE_SIZE_4 | WHITENING_OFF | CRC_ON | ADRSFILT_NONE,
/* 31 */ FIFO_AUTOCLR_ON | FIFO_STBY_ACCESS_WRITE
// Register Set
void RegisterSet(int8 address, int8 value)
output_low(CSCON);
address = (address<<1);
spi_write (address);
spi_write (value);
output_high(CSCON);
// Register Read
int8 RegisterRead(int8 address)
unsigned int8 data_r = 0, dummy_data_r = 0;
output_low(CSCON);
delay_ms(50);
address = ((address<<1)|0x40);
spi_write(dummy_data_r);
data_r = spi_read(dummy_data_r);
output_high(CSCON);
return data_r;
// SetRFMode(int8 mode)
// Sets the MRF89XA transceiver operating mode to:
// sleep, transmit, receive or standby
void SetRFMode(int8 mode)
int8 mcparam0_read;
mcparam0_read = RegisterRead(REG_MCPARAM0);
switch (mode) {
case RF_TRANSMITTER:
RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_TRANSMITTER);
RF_Mode = RF_TRANSMITTER; //RF in TX mode
case RF_RECEIVER:
RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_RECEIVER);
RF_Mode = RF_RECEIVER; //RF in RX mode
case RF_SYNTHESIZER:
RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_SYNTHESIZER);
RF_Mode = RF_SYNTHESIZER; //RF in Synthesizer mode
case RF_STANDBY:
RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_STANDBY);
RF_Mode = RF_STANDBY; //RF in standby mode
case RF_SLEEP:
RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_SLEEP);
RF_Mode = RF_SLEEP; //RF in sleep mode
// WriteFIFO(BYTE Data)
// Fills the FIFO
void WriteFIFO(int8 Data)
output_low(CSDATA);
spi_write(Data);
output_high(CSDATA);
// ReadFIFO(void)
// Reads the Reiceved frame from the fifo and sets hasPacket accordingly
unsigned int8 ReadFIFO(void)
output_low(CSDATA);
return data_r;
// MRF89XAInit(void)
// This function reads the Reiceved frame from the fifo and sets hasPacket accordingly
void MRF89XAInit(void)
int8 input,i=0;
for (i = 0 ; i <= 31; i++)
RegisterSet(i, InitConfigRegs[i]);
input = RegisterRead(REG_MCPARAM0);
RegisterSet(REG_MCPARAM0, (input & 0x1F) | RF_SYNTHESIZER);
/* clear PLL_LOCK flag so we can see it restore on the new frequency */\
input = RegisterRead(REG_IRQPARAM1);
RegisterSet(REG_IRQPARAM1, (input | 0x02));
RegisterSet(REG_MCPARAM0, ((input & 0xE7) | FREQBAND_915));
//Program R, P,S registers
RegisterSet(REG_R1, 119);
RegisterSet(REG_P1, 100);
RegisterSet(REG_S1, 52);
RegisterSet(REG_MCPARAM0, ((input & 0x1F) | RF_SYNTHESIZER));
SetRFMode(RF_STANDBY);
//PHY_IRQ1_En = 1;
// Send_Packet(int8 TxPacketLen)
// Send the packet in the buffer TxPacket
void Send_Packet(int8 TxPacketLen)
int8 i;
int8 j;
RegisterSet(REG_PKTPARAM3, ((InitConfigRegs[REG_PKTPARAM3] & 0xBF)| FIFO_STBY_ACCESS_WRITE));
RegisterSet(REG_IRQPARAM0, (InitConfigRegs[REG_IRQPARAM0] | IRQ1_FIFO_OVERRUN_CLEAR ));
RegisterSet(REG_IRQPARAM1, ((InitConfigRegs[REG_IRQPARAM1]) | 0x02));
WriteFIFO(TxPacketLen+1);
WriteFIFO(0x05); //Node_adrs
for(i=0; i< TxPacketLen; i++)
WriteFIFO(TxPacket[i]);
SetRFMode(RF_TRANSMITTER);
//Reset FIFO
j = RegisterRead(REG_IRQPARAM0);
RegisterSet(REG_IRQPARAM0, (j | 0x01));
// ReceiveFrame(void)
void ReceiveFrame(void)
int8 data, node_adrs;
int8 i = 0;
int8 j = 0;
// if(IRQ1_Received)
RxPacketLen = ReadFIFO();
DRxPacketLen =RxPacketLen;
node_adrs = ReadFIFO();
Dnode_adrs =node_adrs;
RxPacketLen = (RxPacketLen-1);
while(RxPacketLen--)
data = ReadFIFO();
RxPacket[i] = data;
i++;
RxPacketLen = i;
// IRQ1_Received = FALSE;
hasPacket = TRUE;
//Reset FIFO
MRF89XA.h
* MRF89XA Radio specific defs.
* Company: Microchip Technology, Inc.
* Software License Agreement
* The software supplied herewith by Microchip Technology Incorporated
* (the “Company”) for its PICmicro® Microcontroller is intended and
* supplied to you, the Company’s customer, for use solely and
* exclusively on Microchip PICmicro Microcontroller products. The
* software is owned by the Company and/or its supplier, and is
* protected under applicable copyright laws. All rights are reserved.
* Any use in violation of the foregoing restrictions may subject the
* user to criminal sanctions under applicable laws, as well as to
* civil liability for the breach of the terms and conditions of this
* license.
* THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
* WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
* TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
* PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
* IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#ifndef _MRF89XA_
#define _MRF89XA_
MRF89XA Operating modes
#define RF_SLEEP 0x00
#define RF_STANDBY 0x20
#define RF_SYNTHESIZER 0x40
#define RF_RECEIVER 0x60
#define RF_TRANSMITTER 0x80
MRF89XA Register Description
#define REG_MCPARAM0 0
#define CHIPMODE_SLEEPMODE 0x00 //000 [7:5]
#define CHIPMODE_STBYMODE 0x20 //001 ;default
#define CHIPMODE_FSMODE 0x40 //010
#define CHIPMODE_RX 0x60 //011
#define CHIPMODE_TX 0x80 //100
#define FREQBAND_902 0x00 //902-915 00 [4:3]
#define FREQBAND_915 0x08 //915-928 01 ;default
#define FREQBAND_950 0x10 //950-960 or 863-870 10
#define VCO_TRIM_00 0x00 // [2:1] Vtune determined by tank inductor values
#define VCO_TRIM_01 0x02
#define VCO_TRIM_10 0x04
#define VCO_TRIM_11 0x06
#define REG_MCPARAM1 1
#define MODSEL_OOK 0x40 //01 [7:6]
#define MODSEL_FSK 0x80 //10 ;default
#define OOKTHRESHTYPE_FIXED 0x00 //00 [4:3]
#define OOKTHRESHTYPE_PEAK 0x08 //01
#define OOKTHRESHTYPE_AVG 0x10 //10
#define DATAMODE_CONTINUOUS 0x00 //00 [Bit2,Bit5];default
#define DATAMODE_BUFFERED 0x20 //01
#define DATAMODE_PACKET 0x04 //1x
#define IFGAIN_0 0x00 //00 [1:0] 0dB ;default
#define IFGAIN_45 0x01 //01 -4.5dB
#define IFGAIN_9 0x02 //10 -9dB
#define IFGAIN_135 0x03 //11 -13.5dB
#define REG_FREGDEV 2 //default D = 00000011, FDEV = 133 kHz
//values may change - should be calculated based on crystal frequency - 12.8 MHz (fxtal/32/(D+1))
#define FREGDEV_33 0x0B
#define FREGDEV_40 0x09
#define FREGDEV_50 0x07
#define FREGDEV_67 0x05
#define FREGDEV_80 0x04
#define FREGDEV_100 0x03
#define FREGDEV_133 0x02
#define FREGDEV_200 0x01
#define REG_BITRATE 3
//default C = 0000111, BR = 25 Kbps
#define BITRATE_200 0x00
#define BITRATE_100 0x01
#define BITRATE_66 0x02
#define BITRATE_50 0x03
#define BITRATE_40 0x04
#define BITRATE_25 0x07
#define BITRATE_20 0x09
#define BITRATE_16 0x0B
#define BITRATE_10 0x13
#define BITRATE_5 0x27
#define BITRATE_2 0x63
#define BITRATE_1_56 0x7F
#define BITRATE_2_41 0x52
#define BITRATE_4_76 0x29
#define BITRATE_8 0x18
#define BITRATE_9_52 0x14
#define BITRATE_12_5 0x0F
#define BITRATE_16_67 0x0B
#define REG_OOKFLOORTHRESH 4
// OOK threshold (reg4)
#define OOKFLOORTHRESH_VALUE 0x0C
#define REG_MCPARAM5 5
#define FIFOSIZE_16 0x00 //00 [7:6] - 16bytes - default
#define FIFOSIZE_32 0x40
#define FIFOSIZE_48 0x80
#define FIFOSIZE_64 0xC0
#define FIFO_THRSHOLD_31 0x0F //31 bytes - default [5:0]
#define FIFO_THRSHOLD_1 0x01
#define REG_R1 6
#define REG_P1 7
#define REG_S1 8
#define REG_R2 9
#define REG_P2 10
#define REG_S2 11
#define REG_MCPARAM12 12
#define PA_RAMP_3 0x00 //[4:3] - 3us
#define PA_RAMP_85 0x08 //8.5us
#define PA_RAMP_15 0x10 //15us
#define PA_RAMP_23 0x18 //23us
#define DEF_PARAMP 0x20
#define REG_IRQPARAM0 13
// IRQ Param 0 (reg13)
// Select RX&STDBY IRQ_0 sources (Packet mode) (reg13)
#define IRQ0_RX_STDBY_PAYLOADREADY 0x00
#define IRQ0_RX_STDBY_WRITEBYTE 0x40
#define IRQ0_RX_STDBY_FIFOEMPTY 0x80
#define IRQ0_RX_STDBY_SYNCADRS 0xC0
// Select RX&STDBY IRQ_1 sources (Packet mode) (reg13)
#define IRQ1_RX_STDBY_CRCOK 0x00
#define IRQ1_RX_STDBY_FIFOFULL 0x10
#define IRQ1_RX_STDBY_RSSI 0x20
#define IRQ1_RX_STDBY_FIFOTHRESH 0x30
// Select TX IRQ_1 sources (Packet mode) (reg13)
#define IRQ1_TX_FIFOFULL 0x00
#define IRQ1_TX_TXDONE 0x08
// Select TX IRQ_1 sources (Continuous mode) (reg13)
#define IRQ1_TX_DCLK 0x00
// FIFO overrun/clear (reg13)
#define IRQ1_FIFO_OVERRUN_CLEAR 0x01
#define REG_IRQPARAM1 14
// IRQ Param 1
#define DEF_IRQPARAM1 0x08
// Select TX start condition and IRQ_0 source (Packet mode)
#define IRQ0_TX_START_FIFOTHRESH 0x00
#define IRQ0_TX_START_FIFONOTEMPTY 0x10
// RSSI IRQ flag
#define IRQ1_RSSI_IRQ_CLEAR 0x04
// PLL_Locked flag
#define IRQ1_PLL_LOCK_CLEAR 0x02
// PLL_Locked pin
#define IRQ1_PLL_LOCK_PIN_OFF 0x00
#define IRQ1_PLL_LOCK_PIN_ON 0x01
// RSSI threshold for interrupt
#define RSSIIRQTHRESH_VALUE 0x00
#define NODEADRS_VALUE 0x00
#define REG_RSSIIRQTHRESH 15
#define REG_RXPARAM0 16
// RX Param 0
// Passive filter (kHz)
#define PASSIVEFILT_65 0x00 //65 KHz
#define PASSIVEFILT_82 0x10 //82 KHz
#define PASSIVEFILT_109 0x20
#define PASSIVEFILT_137 0x30
#define PASSIVEFILT_157 0x40
#define PASSIVEFILT_184 0x50
#define PASSIVEFILT_211 0x60
#define PASSIVEFILT_234 0x70
#define PASSIVEFILT_262 0x80
#define PASSIVEFILT_321 0x90
#define PASSIVEFILT_378 0xA0
#define PASSIVEFILT_414 0xB0
#define PASSIVEFILT_458 0xC0
#define PASSIVEFILT_514 0xD0
#define PASSIVEFILT_676 0xE0
#define PASSIVEFILT_987 0xF0
// Butterworth filter (kHz)
#define RXFC_VALUE 0x03
// !!! Values defined below only apply if XTAL frequency == 12.8MHz !!!
#define RXFC_FOPLUS25 0x00
#define RXFC_FOPLUS50 0x01
#define RXFC_FOPLUS75 0x02
#define RXFC_FOPLUS100 0x03
#define RXFC_FOPLUS125 0x04
#define RXFC_FOPLUS150 0x05
#define RXFC_FOPLUS175 0x06
#define RXFC_FOPLUS200 0x07
#define RXFC_FOPLUS225 0x08
#define RXFC_FOPLUS250 0x09
#define RXFC_FOPLUS275 0x0A
#define RXFC_FOPLUS300 0x0B
#define RXFC_FOPLUS325 0x0C
#define RXFC_FOPLUS350 0x0D
#define RXFC_FOPLUS375 0x0E
#define RXFC_FOPLUS400 0x0F
#define REG_RXPARAM1 17
// RX Param 1
#define DEF_RXPARAM1 0x08
// Polyphase filter center value (kHz)
#define FO_VALUE 0x30
// !!! Values defined below only apply if RFCLKREF = DEFAULT VALUE = 0x07 !!!
#define FO_50 0x10
#define FO_75 0x20
#define FO_100 0x30
#define FO_125 0x40
#define FO_150 0x50
#define FO_175 0x60
#define FO_200 0x70
#define FO_225 0x80
#define FO_250 0x90
#define FO_275 0xA0
#define FO_300 0xB0
#define FO_325 0xC0
#define FO_350 0xD0
#define FO_375 0xE0
#define FO_400 0xF0
#define REG_RXPARAM2 18
// Rx Param 2
// Polyphase filter enable
#define POLYPFILT_ON 0x80
#define POLYPFILT_OFF 0x00
#define DEF_RXPARAM2 0x20
#define SYNC_ON 0x20 //[5] - 0 - off, 1 - on
#define SYNC_SIZE_8 0x00 //[4:3] - 00 - 8 bits
#define SYNC_SIZE_16 0x08
#define SYNC_SIZE_24 0x10
#define SYNC_SIZE_32 0x18
#define SYNC_ERRORS_0 0x00 //[2:1] - 00 - 0 error
#define SYNC_ERRORS_1 0x02
#define SYNC_ERRORS_2 0x04
#define SYNC_ERROS_3 0x06
#define REG_RXPARAM3 19 //Reserved
#define DEF_RXPARAM3 0x07
#define REG_RSSIVALUE 20
//RSSI value (READ ONLY)
#define REG_OOKSETTINGS 21
// Rx Param 5
// Decrement step of RSSI threshold in OOK demodulator (peak mode)
#define OOK_THRESH_DECSTEP_000 0x00
#define OOK_THRESH_DECSTEP_001 0x20
#define OOK_THRESH_DECSTEP_010 0x40
#define OOK_THRESH_DECSTEP_011 0x60
#define OOK_THRESH_DECSTEP_100 0x80
#define OOK_THRESH_DECSTEP_101 0xA0
#define OOK_THRESH_DECSTEP_110 0xC0
#define OOK_THRESH_DECSTEP_111 0xE0
// Decrement period of RSSI threshold in OOK demodulator (peak mode)
#define OOK_THRESH_DECPERIOD_000 0x00
#define OOK_THRESH_DECPERIOD_001 0x04
#define OOK_THRESH_DECPERIOD_010 0x08
#define OOK_THRESH_DECPERIOD_011 0x0C
#define OOK_THRESH_DECPERIOD_100 0x10
#define OOK_THRESH_DECPERIOD_101 0x14
#define OOK_THRESH_DECPERIOD_110 0x18
#define OOK_THRESH_DECPERIOD_111 0x1C
// Cutoff freq of average function of RSSI threshold in OOK demodulator (average mode)
#define OOK_THRESH_AVERAGING_00 0x00
#define OOK_THRESH_AVERAGING_11 0x03
#define REG_SYNCBYTE0 22
#define REG_SYNCBYTE1 23
#define REG_SYNCBYTE2 24
#define REG_SYNCBYTE3 25
#define REG_TXPARAM 26
// TX Param
// Interpolator filter Tx (kHz)
#define FC_VALUE 0x70
#define FC_25 0x00
#define FC_50 0x10
#define FC_75 0x20
#define FC_100 0x30
#define FC_125 0x40
#define FC_150 0x50
#define FC_175 0x60
#define FC_200 0x70
#define FC_225 0x80
#define FC_250 0x90
#define FC_275 0xA0
#define FC_300 0xB0
#define FC_325 0xC0
#define FC_350 0xD0
#define FC_375 0xE0
#define FC_400 0xF0
#define TXPOWER_13 0x00 //[3:1] - 13dB
#define TXPOWER_10 0x02
#define TXPOWER_7 0x04
#define TXPOWER_4 0x06
#define TXPOWER_1 0x08
#define TXPOWER_2 0x0A
#define TXPOWER_5 0x0C
#define TXPOWER_8 0x0E
#define REG_OSCPARAM 27
// OSC Param
// CLKOUT enable
#define CLKOUT_ON 0x80
#define CLKOUT_OFF 0x00
// CLKOUT frequency (kHz)
#define CLKOUT_12800 0x00
#define CLKOUTint64_t00 0x04
#define CLKOUT_3200 0x08
#define CLKOUT_2133 0x0C
#define CLKOUT_1600 0x10
#define CLKOUT_1280 0x14
#define CLKOUT_1067 0x18
#define CLKOUT_914 0x1C
#define CLKOUT_800 0x20
#define CLKOUT_711 0x24
#define CLKOUT_64 0x28
#define CLKOUT_582 0x2C
#define CLKOUT_533 0x30
#define CLKOUT_492 0x34
#define CLKOUT_457 0x38
#define CLKOUT_427 0x3C
#define REG_PKTPARAM0 28
#define MANCHESTER_ON 0x80 //[7] 0 - off, 1 - on
#define MANCHESTER_OFF 0x00
#define REG_NODEADDRESS 29
#define REG_PKTPARAM2 30
#define PKT_FORMAT_FIXED 0x00 //[7] 0 - fixed length, 1- variable length
#define PKT_FORMAT_VARIABLE 0x80
#define PREAMBLE_SIZE_1 0x00 //[6:5] 00 - 1 byte
#define PREAMBLE_SIZE_2 0x20
#define PREAMBLE_SIZE_3 0x40
#define PREAMBLE_SIZE_4 0x60
#define WHITENING_ON 0x10 //[4] 0 - off, 1 - On
#define WHITENING_OFF 0x00
#define CRC_ON 0x08 //[3] 0 - off, 1 - On
#define CRC_OFF 0x00
// Address filtering
#define ADRSFILT_NONE 0x00 /* no filtering */
#define ADRSFILT_ME_ONLY 0x02 /* only Node_adrs accepted (register 29) */
#define ADRSFILT_ME_AND_00 0x04 /* Node_adrs and 0x00 accepted */
#define ADRSFILT_ME_AND_00_AND_FF 0x06 /* Node_adrs and 0x00 and 0xff accepted */
#define REG_PKTPARAM3 31
#define FIFO_AUTOCLR_ON 0x00 //[7] 0 - On, 1 - Off
#define FIFO_AUTOCLR_OFF 0x80
#define FIFO_STBY_ACCESS_WRITE 0x00 //[6] 0 - Write, 1 - Read
#define FIFO_STBY_ACCESS_READ 0x40
TX.C
#include <18f46k20.h>
#fuses INTRC // Internal RC Osc
#fuses NODEBUG // No Debug mode for ICD
#fuses NOWRT // Program memory not write protected
#fuses NOCPD // No EE protection
#fuses NOLVP // No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#fuses NOPUT // No Power Up Timer
#fuses NOBROWNOUT // Reset when brownout detected
#fuses BORV30 // Brownout reset at 3.0V
#fuses NOWDT // No Watch Dog Timer
#fuses MCLR // Master Clear pin enabled
// Clock
#use delay(internal=4000000, restart_wdt) // inclure procédure de délais (delay_ms() et delay_us())
// Define
// CSCON => D2
// CSDATA => D0
// SDI => C5
// SDO => C4
// SCK => C3
// IRQ0 => NC
// IRQ1 => NC
// RESET => D1
#define PACKET_LEN 64
#define CSDATA PIN_D0 // Serial Interface CS data
#define CSCON PIN_D2 // Serial Interface CS Conf
#define RESET PIN_D1 // Reset
// Global
int8 RF_Mode;
int8 TxPacket[PACKET_LEN];
int8 RxPacketLen=0;
int8 RxPacket[PACKET_LEN];
int1 hasPacket = FALSE;
// Debug
int8 Dnode_adrs;
int8 DRxPacketLen;
// Include
#include <MRF89XA.c>
// Main
output_high(CSCON);
output_high(PIN_C6); // pin Power ON
output_high(PIN_B2); // Led Green
output_high(RESET); // reset pin
//Setup OSC
setup_oscillator(OSC_4MHZ|OSC_INTRC);
//Setup SPI
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H );
//Init radio
MRF89XAInit();
//TX
TxPacket[0] = 1;
TxPacket[1] = 2;
TxPacket[2] = 3;
TxPacket[3] = 4;
// RX
RxPacket[0] = 0;
//send
output_high(PIN_B5); //led blue
Send_Packet(64);
output_low(PIN_B5); // led blue
RX.C
// Clock
// Define
// CSCON => D2
// CSDATA => D0
// SDI => C5
// SDO => C4
// SCK => C3
// IRQ0 => NC
// IRQ1 => NC
// RESET => D1
// Global
int8 RF_Mode;
int8 RxPacketLen=0;
// Debug
int8 Dnode_adrs;
int8 DRxPacketLen;
// Include
// Main
delay_ms(2000);
output_high(CSCON);
//Setup OSC
//Setup SPI
//Init radio
MRF89XAInit();
//TX
TxPacket[0] = 1;
TxPacket[1] = 2;
TxPacket[2] = 3;
TxPacket[3] = 4;
// RX
RxPacket[0] = 0;
SetRFMode(RF_RECEIVER);
ReceiveFrame();
if (RXpacket[0]==1)
output_high(PIN_B5); // led Blue
output_low(PIN_B5); // led Blue
Fifo in RX is always empty, I don't use IRQ0 and IRQ1 for the moment. |
Joined: 01 Jul 2010 Posts: 9107 Location: Greensville,Ontario
Posted: Tue Feb 05, 2019 11:47 am |
Without looking at all the code...a couple of 'low level' questions...
1) do you have the correct power for the devices ? Most 'peripherals' are 3 volts these days...have you enough current to power it as well ?
2) can you actually set and read various registers of the device for both xmtr and rcvr units ??
in_nursery
Posted: Tue Feb 05, 2019 2:45 pm |
So voltage is 3.3V
after some small issue I check that I can read and write configuration on each.
but still no RX.
I change:
#fuses INTRC_IO
and
output_low(RESET); // reset pin |
