When i program pic16f877a sometimes i forget unchecking the eeprom data write section on pickit2. Because i do some eeprom writings and i don't want them to be lost. In recent days i have learned that CPD fuse of pic16f877a inhibits external data writings and readings. Although i write 0 on CPD fuse (İ also checked CPD is 0 in the pickit2). Pickit2 sets all the eeprom data to FF. What am i doing wrong? (By the way when i try to read the eeprom data pickit2 reads all 0).
Posted: Thu Dec 27, 2018 8:44 am
You need to change the erase mode, to 'erase when needed'. Otherwise the
programmer may be fully erasing the chip, which will overwrite the CPD
fuse.
