hemnath
| float value to PC |
Posted: Thu Sep 27, 2018 11:04 pm |
I want to transfer float value to PC.
Compiler Version: V4.114
Sample code:
#include "18F2520.h"
#fuses HS
#include "ieeefloat.c"
float f;
int32 PCval;
int8 *p;
f = 0.0123;
PCval=f_PICtoIEEE(f);
p = &PCval; // pointer p points to the first byte of f
putc(p[0]); // use p as an array Send the first byte
putc(p[1]); // Send the second byte
putc(p[2]); // Send the third byte
putc(p[3]); // Send the fourth byte
I get the following errors:
*** Error 12 "main.c" Line 19(5,6): Undefined identifier -- putchar
*** Error 12 "main.c" Line 20(5,6): Undefined identifier -- putchar
*** Error 12 "main.c" Line 21(5,6): Undefined identifier -- putchar
*** Error 12 "main.c" Line 22(5,6): Undefined identifier -- putchar |
hemnath
Posted: Thu Sep 27, 2018 11:20 pm |
Added the line.
Now it compiles successfully. |
Joined: 01 Jul 2010 Posts: 9630 Location: Greensville,Ontario
Posted: Fri Sep 28, 2018 5:06 am |
| Be sure to add 'ERRORS' to the #USE RS232(...options...) ! While it does nothing on sending data when you have the PIC RECEIVE data, it'll keep the PIC from 'locking up'. |
