timk
| Problems with I2C on dsPIC30F6015 |
Posted: Tue Aug 21, 2018 3:37 am |
I got problems to send messages via I2C of the dsPIC30F6015.
I just want to get a really simple program to work.
#use i2c(master,I2C1,stream=I2C_NFC)
i2c_start(I2C_NFC);
i2c_write(I2C_NFC, 0xFF);
i2c_stop(I2C_NFC);
The program is just a test program.
The compiler says """Error 12... Unknown identifier: I2C_NFC
I think is a small syntax-error.
Thanks in advance. |
Posted: Tue Aug 21, 2018 4:15 am |
First question. What compiler version?. On very old compilers I2C streams didn't exist.
However assuming something from the last few years, what you post works:
#include <30F6015.h>
#device ICSP=1
#use delay(crystal=20000000)
i2c_start(I2C_NFC);
i2c_stop(I2C_NFC);
Compiles fine.
One thing that can happen, is a 'hidden' character. If you have typed a non displayable character in one of the I2C_NFC parts, then this would be the complaint you would get. |
