AES-128
pilar
AES-128
PostPosted: Mon Jul 16, 2018 11:11 am     Reply with quote
HI
I'm trying to move this code of AES-128 to CCS for a PIC18F4620, apparently I have no memory problems but the encrypted and decrypted data does not match, someone has managed to make it work, can you give me any suggestions ?
Here is my code:
#include <18F4520.h>
#DEVICE ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)// RS232 Estándar
const unsigned char sbox[256] =   {
//0     1    2      3     4    5     6     7      8    9     A      B    C     D     E     F
0x63, 0x7c, 0x77, 0x7b, 0xf2, 0x6b, 0x6f, 0xc5, 0x30, 0x01, 0x67, 0x2b, 0xfe, 0xd7, 0xab, 0x76, //0
0xca, 0x82, 0xc9, 0x7d, 0xfa, 0x59, 0x47, 0xf0, 0xad, 0xd4, 0xa2, 0xaf, 0x9c, 0xa4, 0x72, 0xc0, //1
0xb7, 0xfd, 0x93, 0x26, 0x36, 0x3f, 0xf7, 0xcc, 0x34, 0xa5, 0xe5, 0xf1, 0x71, 0xd8, 0x31, 0x15, //2
0x04, 0xc7, 0x23, 0xc3, 0x18, 0x96, 0x05, 0x9a, 0x07, 0x12, 0x80, 0xe2, 0xeb, 0x27, 0xb2, 0x75, //3
0x09, 0x83, 0x2c, 0x1a, 0x1b, 0x6e, 0x5a, 0xa0, 0x52, 0x3b, 0xd6, 0xb3, 0x29, 0xe3, 0x2f, 0x84, //4
0x53, 0xd1, 0x00, 0xed, 0x20, 0xfc, 0xb1, 0x5b, 0x6a, 0xcb, 0xbe, 0x39, 0x4a, 0x4c, 0x58, 0xcf, //5
0xd0, 0xef, 0xaa, 0xfb, 0x43, 0x4d, 0x33, 0x85, 0x45, 0xf9, 0x02, 0x7f, 0x50, 0x3c, 0x9f, 0xa8, //6
0x51, 0xa3, 0x40, 0x8f, 0x92, 0x9d, 0x38, 0xf5, 0xbc, 0xb6, 0xda, 0x21, 0x10, 0xff, 0xf3, 0xd2, //7
0xcd, 0x0c, 0x13, 0xec, 0x5f, 0x97, 0x44, 0x17, 0xc4, 0xa7, 0x7e, 0x3d, 0x64, 0x5d, 0x19, 0x73, //8
0x60, 0x81, 0x4f, 0xdc, 0x22, 0x2a, 0x90, 0x88, 0x46, 0xee, 0xb8, 0x14, 0xde, 0x5e, 0x0b, 0xdb, //9
0xe0, 0x32, 0x3a, 0x0a, 0x49, 0x06, 0x24, 0x5c, 0xc2, 0xd3, 0xac, 0x62, 0x91, 0x95, 0xe4, 0x79, //A
0xe7, 0xc8, 0x37, 0x6d, 0x8d, 0xd5, 0x4e, 0xa9, 0x6c, 0x56, 0xf4, 0xea, 0x65, 0x7a, 0xae, 0x08, //B
0xba, 0x78, 0x25, 0x2e, 0x1c, 0xa6, 0xb4, 0xc6, 0xe8, 0xdd, 0x74, 0x1f, 0x4b, 0xbd, 0x8b, 0x8a, //C
0x70, 0x3e, 0xb5, 0x66, 0x48, 0x03, 0xf6, 0x0e, 0x61, 0x35, 0x57, 0xb9, 0x86, 0xc1, 0x1d, 0x9e, //D
0xe1, 0xf8, 0x98, 0x11, 0x69, 0xd9, 0x8e, 0x94, 0x9b, 0x1e, 0x87, 0xe9, 0xce, 0x55, 0x28, 0xdf, //E
0x8c, 0xa1, 0x89, 0x0d, 0xbf, 0xe6, 0x42, 0x68, 0x41, 0x99, 0x2d, 0x0f, 0xb0, 0x54, 0xbb, 0x16 }; //F
// multiply by 2 in the galois field
unsigned char galois_mul2(unsigned char value)
  signed char temp;
  // cast to signed value
  temp = (signed char) value;
  // if MSB is 1, then this will signed extend and fill the temp variable with 1's
  temp = temp >> 7;
  // AND with the reduction variable
  temp = temp & 0x1b;
  // finally shift and reduce the value
  return ((value << 1)^temp);
// aes encryption function
// It manipulates the state and computes the key schedule on the fly
void aes_encrypt(unsigned char *state, unsigned char *key)
  unsigned char buf1, buf2, buf3, buf4, round, i;
  unsigned char rcon;
  // Rcon initial value. All subsequent values are computed.
  rcon = 0x01;
  // main AES data loop
  for (round = 0; round < 10; round++){
    //add key + sbox
    for (i = 0; i <16; i++){
      state[i]=sbox[state[i] ^ key[i]];
    //shift rows
    buf1 = state[1];
    state[1] = state[5];
    state[5] = state[9];
    state[9] = state[13];
    state[13] = buf1;
    buf1 = state[2];
    buf2 = state[6];
    state[2] = state[10];
    state[6] = state[14];
    state[10] = buf1;
    state[14] = buf2;
    buf1 = state[15];
    state[15] = state[11];
    state[11] = state[7];
    state[7] = state[3];
    state[3] = buf1;
    //process mixcolumn for all rounds but the last one
    if (round < 9) {
      for (i=0; i <4; i++){
        // compute the current index
        buf4 = (i << 2);
   buf1 = state[buf4] ^ (state[buf4+1]) ^ (state[buf4+2]) ^ (state[buf4+3]);
   buf2 = state[buf4];
   buf3 = state[buf4]^(state[buf4+1]); buf3=galois_mul2(buf3); state[buf4] = state[buf4] ^ buf3 ^ buf1;
   buf3 = state[buf4+1]^(state[buf4+2]); buf3=galois_mul2(buf3); state[buf4+1] = state[buf4+1] ^ buf3 ^ buf1;
   buf3 = state[buf4+3]^buf2;     buf3=galois_mul2(buf3); state[buf4+3] = state[buf4+3] ^ buf3 ^ buf1;
    //key schedule
    // compute the 16 next round key bytes
    key[0] = sbox[key[13]]^key[0]^rcon;
    key[1] = sbox[key[14]]^key[1];
    key[2] = sbox[key[15]]^key[2];
    key[3] = sbox[key[12]]^key[3];
    for (i=4; i<16; i++) {
   key[i] = key[i] ^ (key[i-4]);
    // compute the next Rcon value
    rcon = galois_mul2(rcon);
  // process last AddRoundKey
    state[i]=state[i] ^ key[i];
printf("%x",state[i]);      //   Print DATA Encrypt !!!!
int main( void ){
unsigned char state[] = {0x00, 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88, 0x99, 0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff};
unsigned char ciphertext[] = {0x69, 0xc4, 0xe0, 0xd8, 0x6a, 0x7b, 0x04, 0x30, 0xd8, 0xcd, 0xb7, 0x80, 0x70, 0xb4, 0xc5, 0x5a};
unsigned char key[]   = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f};
unsigned char i;
unsigned char err_count = 0;
  aes_encrypt(state,key);
  for (i=0;i<16;i++) {
    if (state[i] != ciphertext[i]) {
      err_count++;
  return 0;
The encrypted data must be identical to: ciphertext[] = {0x69, 0xc4, 0xe0, 0xd8, 0x6a, 0x7b, 0x04, 0x30, 0xd8, 0xcd, 0xb7, 0x80, 0x70, 0xb4, 0xc5, 0x5a};
but I'm getting: 0xe1, 0x69, 0x6c, 0x5b, 0x40, 0x46, 0x72, 0xc5, 0x45, 0x26, 0x4a, 0x82, 0x3a, 0x68, 0x35, 0x6f
PostPosted: Mon Jul 16, 2018 11:33 am     Reply with quote
Your problem will be with this:
  temp = temp >> 7;
This will not happen. CCS shift right does not sign extend. This is 'implementation defined' in C.
Simply test the high bit, and if it is '1' or with 0xFF.
pilar
PostPosted: Mon Jul 16, 2018 11:41 am     Reply with quote
Hi Ttelmah,
I did not understand you, please can you give me an example or tell me how to change it...
PostPosted: Mon Jul 16, 2018 12:43 pm     Reply with quote
CCS performs a logical shift right, not an arithmetic shift right.
Now the operation here is designed to propagate the sign bit down to fill the entire byte.
You can do the same thing with:
if (bit_test(temp,7))
    temp=0xFF;
    temp=0;
So if the sign bit is set, the entire byte gets filled with 1's, if it is not set the byte gets filled with 0's.
