		| Author | Message |
		| Jeetdesai
				| How to transmit characters/special characters over SPI? |
				|  Posted: Tue Jul 10, 2018 8:44 am |   |
				| I can successfully transmit decimal, hex and binary data over SPI. I check my signals by connecting the oscilloscope probes at the data out, clock and enable pins, and observe the waveforms.
 But i'm getting the wrong data when I send characters(A, B ... Z)) or special characters(!, @ ... +). The waveform on the output is the same (01100111) for all alphabetic characters and special characters.
 The following is my code:
  	  | Code: |  	  | #include <18F87K22.h> #FUSES INTRC_IO                  //Internal RC Osc, no CLKOUT
 //#FUSES NOPUT                     //No Power Up Timer
 #FUSES NOPROTECT                 //No code protected from reads
 #FUSES MCLR                      //Master Clear pin enabled
 #FUSES NOCPD                     //No EE protection
 #FUSES NOBROWNOUT                //No brownout reset
 //#FUSES BROWNOUT                  // Hold in reset during brownout - else can corrupt EEPROM, act strange, etc
 #FUSES NOIESO                    //Internal External Switch Over mode disabled
 #FUSES NOFCMEN                   //Fail-safe clock monitor disabled
 #use delay(clock = 1000000)
 #define CS Pin_H0
 //#BYTE ODCON1=
 //#BIT  ODCON1BIT7 = ODCON1.7
 /*#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
 #define SPI_MODE_1  (SPI_L_TO_H)
 #define SPI_MODE_2  (SPI_H_TO_L)
 #define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H) */
 setup_spi(SPI_MASTER | SPI_H_TO_L| SPI_CLK_DIV_64);
 output_low(CS);
 //spi_write(0x55); //hex data
 //spi_write(75); // decimal
 //spi_write(0b11110000); // binary
 spi_write("A"); //Char data
 output_high(CS);
 delay_us(1000);
		| PCM programmer
				|  Posted: Tue Jul 10, 2018 9:34 am |   |
				| This is not the correct way to do it. 	  | Quote: |  	  | spi_write("A"); //Char data |
 The correct way is to use single quotes:
		| Jeetdesai
				|  Posted: Tue Jul 10, 2018 9:46 am |   |
				| Thanks You so much !!! |  |
