sprintf bug?
pmuldoon
sprintf bug?
PostPosted: Mon Jun 04, 2018 8:17 am     Reply with quote
compiler: 5.074
chip: 18F67K40
I have a strange bug in some rather complicated code.
I've narrowed it down and can make/break it by changing an sprintf() statement.
I have a uint32 variable that I am writing to a buffer, and if I use the %ld format it works fine, even though it's unsigned. If I use the %lu format it seems to somehow avoid executing some code.
Can anyone make sense of why the compiler would use a BRA instruction instead of a CALL in the .lst output?
I know I'm probably a rev or two behind. I've requested a maintenance update, but sometimes that takes a while.
here is the %lu version:
    .................... //** reload Tx buffer
    .................... // note: using %lu for 2nd parm caused Vout not to work - don't know why
    .................... // sprintf(TxBuffer+1," %8ld %8ld\r\n",(signed int32)FdcResultCh0 - llZeroOffset,(signed int32)FdcResultCh0);
    .................... sprintf(TxBuffer+1," %10lu\r\n",FdcResultCh0);
    0EBE8: MOVLB 2
    0EBEA: CLRF xFA
    0EBEC: MOVLW 53
    0EBEE: MOVWF xF9
    0EBF0: MOVLW 20
    0EBF2: MOVLB 3
    0EBF4: MOVWF x40
    0EBF6: MOVLB 0
    0EBF8: CALL BEAA
    0EBFC: MOVLW 20
    0EBFE: MOVLB 3
    0EC00: MOVWF x40
    0EC02: MOVLB 0
    0EC04: CALL BEAA
    0EC08: MOVLW 4A
    0EC0A: MOVWF FE9
    0EC0C: MOVFF 28,30E
    0EC10: MOVFF 27,30D
    0EC14: MOVFF 26,30C
    0EC18: MOVFF 25,30B
    0EC1C: BRA E986 // this seems very wrong
    0EC1E: MOVLW 0D
    0EC20: MOVLB 3
    0EC22: MOVWF x40
    0EC24: MOVLB 0
    0EC26: CALL BEAA
    0EC2A: MOVLW 0A
    0EC2C: MOVLB 3
    0EC2E: MOVWF x40
    0EC30: MOVLB 0
    0EC32: CALL BEAA
compiled with %ld
    .................... sprintf(TxBuffer+1," %10ld\r\n",FdcResultCh0);
    0EB22: MOVLB 2
    0EB24: CLRF xFA
    0EB26: MOVLW 53
    0EB28: MOVWF xF9
    0EB2A: MOVLW 20
    0EB2C: MOVLB 3
    0EB2E: MOVWF x40
    0EB30: MOVLB 0
    0EB32: CALL BEAA
    0EB36: MOVLW 20
    0EB38: MOVLB 3
    0EB3A: MOVWF x40
    0EB3C: MOVLB 0
    0EB3E: CALL BEAA
    0EB42: MOVLW 4A
    0EB44: MOVWF FE9
    0EB46: MOVFF 28,337
    0EB4A: MOVFF 27,336
    0EB4E: MOVFF 26,335
    0EB52: MOVFF 25,334
    0EB56: CALL BEFC
    0EB5A: MOVLW 0D
    0EB5C: MOVLB 3
    0EB5E: MOVWF x40
    0EB60: MOVLB 0
    0EB62: CALL BEAA
    0EB66: MOVLW 0A
    0EB68: MOVLB 3
    0EB6A: MOVWF x40
    0EB6C: MOVLB 0
    0EB6E: CALL BEAA
PostPosted: Mon Jun 04, 2018 9:17 am     Reply with quote
If a routine is called only once in a program, the compiler will often do a BRA
to the routine, and then another BRA back to where it was "called" it from.
This is done to save a stack location.
If you want help on this, you should post a very small but complete test
program that is compilable without errors.
pmuldoon
PostPosted: Mon Jun 04, 2018 9:28 am     Reply with quote
Thanks, PCM. I didn't know that.
I'm trying to sort out a bug and changing the sprintf resulted in the exact same symptom. I must be looking in the wrong place. Just not exactly sure what I'm looking for, yet. I'm suspecting it has to do with signed and unsigned int32's.
Is there any way to know if the last few compiler updates that I missed relate to this chip? I looked around on the website but couldn't find anything like a compiler rev history.
PostPosted: Mon Jun 04, 2018 10:37 am     Reply with quote
Here is the version history:
http://www.ccsinfo.com/devices.php?page=versioninfo
But they often make changes that don't get listed in the versions page.
PostPosted: Mon Jun 04, 2018 11:48 am     Reply with quote
As a general comment, the commonest problem with a sprintf, would be not enough space for the output. Remember the trailing \0. An overflow of the target buffer could cause all sorts of oddities.
pmuldoon
PostPosted: Mon Jun 04, 2018 12:53 pm     Reply with quote
That was one of my first thoughts too. but the buffer is 80-bytes and longer strings print out without a problem. (it sure seemed like buffer overflow clobbering another variable)
I'm gonna do some things (set flags/ print variables) to try and narrow down where things are going wrong. I just thought for sure I found something that was closely related because just changing the format from %ld to %lu would make or break it.
Sorry I can't give you more info, but it's a bit complicated and would take a while to write out clearly. If I can't corner it soon I will write up a test program and post it.
Thanks,
PostPosted: Mon Jun 04, 2018 12:57 pm     Reply with quote
Try with a fractionally shorter length for the output. Wondering if something in the printf is overflowing at 10 digits. I know an int32 can give ten digits, but it might be a mode that isn't expected!...
pmuldoon
PostPosted: Mon Jun 04, 2018 1:19 pm     Reply with quote
Excellent thought (it didn't fix it, but worth a try). That would've been exactly the kind of thing I would have hoped to find.
I'm making some of my key local static variables global and printing them out to see the process better.. I already see something that is totally wrong, just need to track down why. It's either me or the compiler - probably me, but I should figure it out soon.
PostPosted: Tue Jun 05, 2018 12:33 am     Reply with quote
Good Luck.. Smile
One thought any possibility of an interrupt event occuring during the print changing something?. For instance if the value being printed was updated in an interrupt I'd be looking at copying it into a local temporary copy before printing. Can you test if the actual print works OK without the other code?.
