eng/ IBRAHIM
| 18f4520 random restart |
Posted: Thu Apr 26, 2018 8:06 pm |
Use pic16f887 to control of ac motor. The code is work fine
but when use pic 18f4520, find two problems:
1- the program is randomly restart (not rest)
2- the value of delay is different at practically
fuse
#device PIC18F4520
#device adc=8
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#use delay(clock=4000000) |
program
int32 var,VARW,VARh,phaseangle,phaseold;
int16 isr_ccp_delta,current_ccp,frequency,rest,speed,j;
signed int16 spdelta,spdeltaold;
#int_EXT
void EXT_isr(void)
static int16 old_ccp = 0;
setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);
current_ccp=get_timer3();
isr_ccp_delta=current_ccp - old_ccp;
old_ccp = current_ccp;
if(varspin==0)
if(frequency>200)
VARW=10000;
if(phaseangle<58000)
phaseangle=58500;
phaseold=58500;
#int_EXT1
void EXT1_isr(void)
set_timer1(phaseangle);
output_low(mot);
if (j==0)
j=1;
ext_int_edge(1, H_TO_L);
else if(j==1)
j=0;
ext_int_edge( 1, L_TO_H);
if(phaseangle>64000)
VARW=10000;
phaseangle=58000;
phaseold=58000;
#int_TIMER1
void TIMER1(void)
output_high(mot);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1|RTCC_8_BIT);
set_timer0(0);
#int_TIMER0
void TIMER0(void)
output_low(mot) ;
void run(speed,rest)
output_high(playled);
isr_ccp_delta=125000;
phaseold=59000;
phaseangle=59000;
output_high(left);
for (VARW=0;VARW<=2100;++VARW)
frequency = (125000 / isr_ccp_delta);
spdelta=speed-frequency;
phaseangle=phaseold+0.8*spdelta-0.4*spdeltaold;
spdeltaold=spdelta;
phaseold=phaseangle;
if(phaseangle>61500)
VARW=10000;
for (VARW=0;VARW<=rest;++VARW)
phaseangle=59000;
phaseold=59000;
output_low(Triac);
output_low(right);
output_low(left);
delay_ms(900);
output_high(right);
spdeltaold=spdelta;
VARW=10000;
phaseold=59000;
phaseangle=59000;
output_low(Triac);
output_low(right);
output_low(left);
delay_ms(900);
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
if(input(start)){output_high(playled);
goto L;
L:
delay_ms(1500);
run(55,7);
Posted: Thu Apr 26, 2018 11:22 pm |
Assuming the code is the same.
Sounds like a classic EMF problem.
The 4520, has a slightly smaller die geometry that the 887. Makes it slightly more sensitive to RFI and supply noise. The early PIC's were very rugged in this regard. Later chips not so good. |
| Re: 18f4520 random restart |
Posted: Thu Apr 26, 2018 11:32 pm |
| eng/ IBRAHIM wrote: |
Use pic16f887 to control of ac motor. The code is work fine but
You suggest that you took the exact same code that worked with the
16F887 and you dropped it into an 18F4520 and it fails.
But it's not the same code that you used on the 16F887. Your code uses
External interrupt 1 and Timer3. Those peripherals are not available in
the 16F887. Therefore, you have substantially changed the code.
It is possible that you introduced errors when you added the changes.
output_low(Triac);
output_high(mot);
output_low(right);
output_low(left);
Disconnect all these devices from the circuit. Then run the PIC.
Does it still do random restarts ? If not, you probably have some
of these problems:
1. Insufficient power supply
2. Insufficient bulk capacitance
3. Insufficient bypass capacitors
4. Poor board layout (thin power supply traces, stubs, lack of ground plane)
5. Triac noise
6. Missing diodes across coils |
Posted: Fri Apr 27, 2018 12:11 am |
I must admit, when I saw 'TRIAC', I felt RFI/EMF was immediately the most likely problem.....
Just how horrible these parts really can be is often missed.
Another question to add:
Is the load exactly the same as was being used before?. |
Posted: Fri Apr 27, 2018 5:45 am |
I see the clock is 40MHz, the 887 tops out at 20MHz. You need really good PCB layout,traces, filters, etc. to run reliably at 40MHz. Also anything attached to PIC pins needs to be '40MHz' compatible meaning,again, wiring, filters, etc. Is the PCB super clean, all solder joints shiny, everything well soldered? I got bit by a pot wiper NOT being soldered once, It took 3 MONTHS to figure that out as it 'mostly worked'.
In effect, you've 'overclocked' your program and PIC environment.
Now maybe, this isn't the core to your problem but 'noise' comes from a LOT of sources and can be difficult to track down.
just somethings to consider.
eng/ IBRAHIM
Posted: Fri Apr 27, 2018 9:41 am |
When the problem occurred after changing the pic on the same PCB and on the same motor
I took into account the differences between them and I changed Timer 2 to Timer 3. Change #int_rb to #int_EXT1 . But remained the same problem.
When disable #int_TIMER0 ( or disable #int_TIMER01 ), the motor does not work but the problem disappears.
I've met the noise problem before and solved it.
But it was causing RESET not RESTART ( The program starts from the beginning, with the playled still working without pressing the start). |
Posted: Fri Apr 27, 2018 11:05 pm |
The 3 variables shown in bold are not initialized at the start of main():
| Quote: |
int16 isr_ccp_delta, current_ccp, frequency, rest, speed, j;
The variable 'rest' is used in two for() loops, but is never set to a value
in your program !
| Quote: |
for (VARW=0; VARW <= rest; ++VARW)
The 'speed' variable is used in two calculations but it's never set to any value !
| Quote: |
Your program doesn't compile. It gives these errors
| Quote: |
>>> Warning 204 "PCH_Test.c" Line 45(1,1): Condition always FALSE varspin
*** Error 12 "PCH_Test.c" Line 45(4,11): Undefined identifier varspin
*** Error 12 "PCH_Test.c" Line 67(12,15): Undefined identifier mot
*** Error 12 "PCH_Test.c" Line 92(13,16): Undefined identifier mot
*** Error 12 "PCH_Test.c" Line 101(12,15): Undefined identifier mot
*** Error 12 "PCH_Test.c" Line 107(13,20): Undefined identifier playled
*** Error 12 "PCH_Test.c" Line 111(13,17): Undefined identifier left
*** Error 12 "PCH_Test.c" Line 134(12,17): Undefined identifier Triac
*** Error 12 "PCH_Test.c" Line 136(12,17): Undefined identifier right
*** Error 12 "PCH_Test.c" Line 137(12,16): Undefined identifier left
*** Error 12 "PCH_Test.c" Line 141(13,18): Undefined identifier right
*** Error 12 "PCH_Test.c" Line 164(12,17): Undefined identifier Triac
*** Error 12 "PCH_Test.c" Line 166(12,17): Undefined identifier right
*** Error 12 "PCH_Test.c" Line 167(12,16): Undefined identifier left
*** Error 173 "PCH_Test.c" Line 173(6,10): Functions may not be nested
*** Error 12 "PCH_Test.c" Line 184(10,15): Undefined identifier start
*** Error 12 "PCH_Test.c" Line 184(30,37): Undefined identifier playled
*** Error 79 "PCH_Test.c" Line 195(1,2): Expect }
17 Errors, 1 Warnings.
eng/ IBRAHIM
Posted: Sat Apr 28, 2018 7:04 am |
#define start PIN_E1
#define playled PIN_C6
#define standbyled PIN_D5
#define endled PIN_C7
#define right PIN_A3
#define left PIN_C2
#define COD3 PIN_B3
#define COD4 PIN_B4
#define COD5 PIN_A7
#define COD6 PIN_B6
#define TAC PIN_B0
#define mot PIN_C0
#define ZCD PIN_B5
int32 VARW,phaseangle,phaseold;
#int_EXT
void EXT_isr(void)
if(frequency>200)
VARW=10000;
phaseangle=58500;
phaseold=58500;
#int_EXT1
void EXT1_isr(void)
output_low(mot);
if (j==0)
j=1;
else if(j==1)
j=0;
VARW=10000;
phaseangle=58000;
phaseold=58000;
#int_TIMER1
void TIMER1(void)
output_high(mot);
set_timer0(0);
#int_TIMER0
void TIMER0(void)
output_low(mot) ;
phaseold=59000;
phaseangle=59000;
output_high(left);
spdeltaold=spdelta;
VARW=10000;
phaseangle=59000;
phaseold=59000;
output_low(mot);
output_low(right);
output_low(left);
delay_ms(900);
output_high(right);
spdeltaold=spdelta;
VARW=10000;
phaseold=59000;
phaseangle=59000;
output_low(mot);
output_low(right);
output_low(left);
delay_ms(900);
output_high(standbyled);
if(input(start)){output_high(playled);output_low(standbyled);
goto L;
L:
delay_ms(1500);
run(55,5);
program compile no error.
program run fine. Motor run good but The program starts from start randomly. Delay time of rest must be 5sec. In actually rest time is 10sec. |
Posted: Sat Apr 28, 2018 7:18 am |
hmm...
first delay is this..
you say 'rest' delay is really 10 seconds, so that's 20X longer
That could be the clock isn't really running properly.
I suggest you code/compile/run a '1Hz LED' program to confirm/deny the PIC is actually running at the correct speed. Report back what happens.
eng/ IBRAHIM
Posted: Sat Apr 28, 2018 7:53 am |
| temtronic wrote: | hmm...
Clock is really running properly.
When disable #int_TIMER0 ( or disable #int_TIMER01 ), delay_ms(500); give 0.5sec and rest delay is really 5 seconds, and no RESTART. |
Posted: Sat Apr 28, 2018 8:33 am |
1. Post your CCS compiler version.
2. Your latest posted code still is missing the intialization of 'rest' and 'speed'.
Since you want this loop to run at 5 seconds, and it has a total delay
time of 100 ms + 900 ms = 1 second,
| Quote: | for (VARW=0;VARW<=rest;++VARW)
phaseold=59000;
phaseangle=59000;
output_low(mot);
output_low(right);
output_low(left);
delay_ms(900);
I suggest that you initialize 'rest' to 5, like this:
| Quote: | void main()
rest = 5;
enable_interrupts(GLOBAL); |
But you are still doing calculations based on the 'speed' value, and your
code never initializes 'speed'. It probably is 0x0000.
| Quote: |
phaseangle=phaseold+0.8*spdelta-0.4*spdeltaold; |
How can you possibly write your progam without setting 'speed' or 'rest'
to an initial value in main() ? |
eng/ IBRAHIM
Posted: Sat Apr 28, 2018 9:04 am |
CCS compiler version. 4.014
setting 'speed' ;'rest'
are initial value in main() . run(55,5) |
Posted: Sun Apr 29, 2018 12:23 pm |
There are type declaration problems in the code.
First 'run', doesn't declare the types for the variables it is being passed. This is relying on the 'implicit int' rule, but is potentially dangerous.
Then you have:
int16 isr_ccp_delta;
but load this with:
an int16 can hold 65535 maximum. Ugh....
There are several other similar issues.
will have a wrong value because of isr_ccp_delta etc.. |
Posted: Sun Apr 29, 2018 2:30 pm |
I was thinking about HOW could this code have worked on the other PIC as there are lots of small code 'details' any of which can cause failure.
So I suspect it's not hardware related, like EMI or PCB, 'just' code. |
eng/ IBRAHIM
Posted: Sun Apr 29, 2018 7:47 pm |
thanks all
i deleted the
| Code: | enable_interrupts(INT_TIMER0);
from interrupts and but that in RUN loop
phaseold=59000;
phaseangle=59000;
delay_ms(200);
output_high(left);
spdeltaold=spdelta;
VARW=10000;
disable_interrupts(INT_TIMER1);
clear_interrupt(INT_TIMER1);
disable_interrupts(INT_TIMER0);
clear_interrupt(INT_TIMER0);
phaseangle=59000;
phaseold=59000;
output_low(mot);
output_low(right);
output_low(left);
delay_ms(900);
After that the delay time became real and actually. But the RESTART problem still occurs.
but occur after a longer period than before.
Already the same program was used on another pic and works fairly well despite the errors in the code. But these problems did not appear. |
