How to turn off MCLR (16F819) ?
sorasit46
PostPosted: Mon Apr 23, 2018 5:03 pm     Reply with quote
(Header ) #FUSES NOMCLR
I want MCLR pin (A5) can act as a regular digital input.
When low logic input, The chip will run unreliable, and will shut off on unexpectedly.
Please help.
Best regard
PostPosted: Mon Apr 23, 2018 8:19 pm     Reply with quote
You really need to show us your program, That PIC should support the fuse 'nomclr', however something else could be causing the problem you're having, like the WDT being enabled...shorted pins, ??
Jay
PostPosted: Tue Apr 24, 2018 12:36 am     Reply with quote
Also, you have to be very careful when using the MCLR as a conventional input. It does not have any protection diode built in, and if the signal glitches above the supply (even quite a small amount), this can trigger the start of a programming cycle, and reset the chip. It is best to have your own external protection diode on the pin.
